Using add employee from a Schedule Requirement adds all of the employee's time to the requirement
 Version(s):7.10
 Environment:N\A
 Area:N/A
 Subarea:N\A
If we add an employee that was not originally on a schedule, when we enter the available hours for the day, it automatically schedules that employee all of those available hours to the work order task that was used to add said employee regardless of what the planned/scheduled hours are for the job.
Workaround is for the end-user to not use the "Add employee" button from the Scheduled task (requirement) but to add all of the trades' availability from the Availability view > Employee Trade Availability tab instead.
Reported as VSTS#17295 - Using add employee from a Schedule Requirement adds all of the employee's time to the requirement.
