Smart client fails to launch or crashes without an error log entry
 Version(s):7
 Environment:N/A
 Area:N/A
 Subarea:N/A
Problem Description
User smart client fails to launch but smart client / application server are running and there are no errors in the error log attributed to the user who errored.
User instance was installed as a Network Service. The ProgramData\Bentley\Ivara EXP\Logs folder permissions were set to read only for all users, thus the Network Service user was not permitted to update/modify the error log.
Update the folder permissions for all Users of for the Network Service user to full control or to allow read, write and modify.
Note - in cases where this is found, it is good for the user to review all other ProgramData\Bentley sub-folders for the correct permissions. The Remote service, Server Manager, et al, may not have the right permissions to update download packages, deploy smart clients, etc.
See also
SR 7001127947
