| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | 7 | ||
| Area: | N/A | ||
| Subarea: | N/A |
After upgrading Mobile Inspections App v2.3 in early November, user found previous readings on iOS devices were not always available. It will work on some of the indicators if you have the previous readings minimized, navigate back out to the main indicator list and then go back in but if the view is expanded when you go into an indicator it doesn't seem to work on any of them.
This was reported as a bug, VSTS#1069225. This has been fixed in APM Mobile Inspections release 2.4.1, APM release 7.20.
SR 7001519952.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0089507
