Setting checkbox using in line editing does not work
 Version(s):All
 Environment:N\A
 Area:N/A
 Subarea:N\A
Trying to set a check in a checkbox (Boolean) attribute using F2 in-line editing is not working.
Looks like it is going to work, but then blue circle appears for a bit and when done/gone, the check disappears (or visa versa if unchecking)
Verified that the attribute is of the MCLB Configuration's root class and that the Configuration allows in-line editing (appearance tab). No error is reported in the Log
To confirm the edit when using in-line editing, cursor down to the next line.
User was relocating cursor focus to somewhere else on the screen and the edit was being rolled back.
Note; The Enter key works but not consistently - Bug  211265 has been submitted to be fixed in a later release.
SR 7000915492
VSTS 211265
 Original Author:Giselle Notte
