| Product(s): | AssetWise Asset Reliability | ||
| Version(s): | 6.2+ | ||
| Environment: | ODC | ||
| Area: | N/A | ||
| Subarea: | N\A |
Online Data Collection indicator readings are not being collected.
Open the Settings Editor for the server instance(s) that runs the ODC service, and add the following logging:
Review the ODC service's server log file, looking for messages that pertain to the ODC Polling Rule that is not collecting indcator readings, if no readings are collected for the polling rule.
If the problem is specific to one indicator tag, look for a message pertaining to the indicator in question.
If you require assistance the the log file review, please submit at Service Request to APM Support clearly stating the problem area. Be sure to attach the ODC server log to the Service Request.
NOTE: After messages have been logged for the problem Polling Rule and/or problem Indicator Tag, remember to turn off ODC logging. This can be accomplished by returning to the Settings Editor utility, and deleting the Ivara.ServiceProvider.ODC.* logging rule. The change will be effective immediately, so there is no need to stop & restart the ODC server instance.
