Product(s): |
APM Implementation and Performance Management |
Version(s): |
7.5 + |
Environment: |
N\A |
Area: |
N/A |
Subarea: |
N\A |
Errors encountered when trying browse or collect readings from OSI PI after upgrade to APM
Example:
Failed to load plugin [Ivara.ServiceProvider.ODC.PIDAPlugin.dll]. Check server log file for more details
FileNotFoundException Could not load file or assembly 'OSIsoft.AFSDK, Version=4.0.0.0
Failed to process reading request for indicator [PI-Indicatorname] EXCEPTION OCCURRED:MissingMethodException Method not found: 'OSIsoft.AF.Asset.AFValue OSIsoft.AF.PI.PIPoint.CurrentValue()'. at Ivara.ServiceProvider.ODC.PIDAPlugin.PIDAPlugin.GetValues(Indicator indicator) at Ivara.ServiceProvider.ODC.Common.ODCPluginBase.PollIndicator_Impl(EXPLinkSession session, Indicator indicator, ODCReadingCreationRule pollingRule, ODCReadingRequest readingRequest) at Ivara.ServiceProvider.ODC.Common.ODCPluginBase.PollIndicator(EXPLinkSession session, Indicator indicator, ODCReadingRequest readingRequest) at Ivara.ServiceProvider.ODC.IndicatorWrapper.CheckForPollingRequests(EXPLinkSession session, ODCReadingRequest request)
When upgrading to APM 7.5, administrators must install OSIsoft PI AF Client 2015 R2 on the client in order to configure ODC data sources for PI servers and configure indicators that reference PI tags.
APM ODC has been verified to work with OSIsoft PI AF Client 2015 R2 version 2.7.5.7166 for both 32-bit and 64-bit versions of the SDK.
The OSIsoft PI SDK is no longer supported.
7.5 Prerequistes guide, 7.5 Readme.pdf and still the same for R24.0.2
Original Author: |
Giselle Crawford |
