This article shows how to set up Postman with an authentication token that allows users access to your AssetWise Reliability (APM) data.
Tip: Download the Postman desktop app from Postman.com. There is also a web app for Postman.
The procedure explains how to configure the token whether you are using client or user credentials. The steps involved are:
Note: The authorization must be renewed every hour because the Access token has a 60-minute expiration period.
Note: Be sure to adhere to Postman recommendations regarding sensitive data.
1. Open Postman and click Create a collection. Collections let you group related requests, making them easier to access and run.
The Create a New Collection window opens:
2. Enter a name (for example, “Bentley Reliability API”) and description.
3. Select the Authorization tab. In the Type list select “OAuth 2.0”. Authentication is performed with Bentley Identification Management System (IMS) using OpenID Connect/OAuth 2.0.
The window changes accordingly.
4. Scroll down on the right side and configure the new token with either client or user credentials.
For user credentials, enter:
For client credentials, enter:
5. Click Get New Access Token. When the token is created, click Use Token.
6. Click Create. You have now created a collection in Postman.
We recommend defining a variable for the GUID of the tenant ID. You can enter the TenantID GUID once and then reuse it everywhere in the collection. Be sure to use descriptive variable names if you wish to use two or more IDs. For example:
For more information, see the Postman article Store and reuse values using variables.
