Product(s): | APM Implementation and Performance Management | ||
Version(s): | R6+ | ||
Environment: | N\A | ||
Area: | N/A | ||
Subarea: | N\A |
When starting up a APM Server Service, the following message is issued:
The IvaraServer - <port> - <instancename> service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs.
Typically seen when the account running the Service cannot log on to the APM instance:
Original Author: | Giselle Crawford |
