Crash - The data types text and varchar are incompatible in the equal to operator
 Version(s):all
 Environment:N\A
 Area:N/A
 Subarea:N\A
 Defect Number:080272
Defect Description
Issue 080272 - Does not Contain filtering operator on HTML attribute column causes application to crash
Steps to Reproduce
When selecting to view a configuration, the server crashes with the following error:
  1. An error has occurred.
    database.cpp(2919):
    Failed Assert: Database Statement Error:
    DBErrorType = 'dbStatement'
    Native SQL Code = 402
    ODBC sqlstate = 37000
    ODBC errortext = '[Microsoft][SQL Server Native Client 10.0][SQL Server]The data types text and varchar are incompatible in the equal to operator.'
Workaround
Advise users to not use DOES NOT CONTAIN column filter on columns that are HTML fields (typically Description fields)
Fixed in R7.7
 Original Author:Giselle Crawford
