| Product(s): | AssetWise Asset Reliability | ||
| Version(s): | 6.2+ | ||
| Environment: | Application Server | ||
| Area: | Checksheets | ||
| Subarea: | Indicator Readings |
Checksheet processing of indicator readings fails to complete successfully.
Open the Settings Editor for the server instance(s) that runs the Smart-Client Application service, or the Remote Service Provider if the problem is with checksheets uploaded from remote computers, and add the following logging:
Review the service's server log file, looking for messages that pertain to Indicators.
If you require assistance the the log file review, please submit at Service Request to APM Support clearly stating the problem area. Be sure to attach the server log to the Service Request.
NOTE: After messages have been logged for the problem, remember to turn off Indicator logging. This can be accomplished by returning to the Settings Editor utility, and deleting the Ivara.Assetmanagement.Indicators logging rule. The change will be effective immediately, so there is no need to stop & restart the server instance
How to log APM messages to a custom file target
| Original Author: | Roy Suthers |
