| Product(s): | AssetWise Asset Reliability | ||
| Version(s): | 6.2+ | ||
| Environment: | ODC | ||
| Area: | N/A | ||
| Subarea: | N\A |
e.g, Report design will not save.
Open the Settings Editor for the thick-client instance used for the report design, and add the following logging:
Review the thick client's log file, looking for messages that pertain to the new rules.
If you require assistance the the log file review, please submit a Service Request to APM Support clearly stating the problem area, if there is no current service request. Attach the thick-client log to the Service Request.
NOTE: After messages have been logged for the problem, remember to turn off logging for the new rules. This can be accomplished by returning to the Settings Editor utility, and deleting the Ivara.Client.Designer.Reports.* and Ivara.Reporting.* logging rules. The change will be effective immediately, so there is no need to stop & restart the thick-clientinstance.
