Product(s): | APM Implementation and Performance Management | ||
Version(s): | 6.2+ | ||
Environment: | N\A | ||
Area: | N/A | ||
Subarea: | N\A |
When using an ODC connection, password encryption can sometimes generaate a forward slash ("/") as a character in the encrypted password. This will cause a connection failuure, due to an invalid OPC URI.
The log file will record a message that includes an exception similar to the following:
EXCEPTION OCCURRED:ArgumentException Invalid OPC uri opcda://localhost:bentley@user.name:F/BjC5WxStldKqOJiPNVbA==/Matrikon.OPC.Simulation.1/f8582cf2-88fb-11d0-b850-00c0f0104305. Valid format should be opcda|opchda://domain@user:password/progid/clsid
Until this problem is fixed in a future release, do not specify a user and password in the ODC data source, in which case Windows authentication will be used by default.
Ensure that the ODC service provider's Windows domain user has administrator privileges on the host computer, to allow access the data.
N/A.
Original Author: | Roy Suthers |
