Entering Downtime incident is very slow
 Version(s):prior to 712.1
 Environment:all
 Area:N/A
 Subarea:N\A
System slows to a crawl when adding a new downtime entry to an asset.
Each time a  downtime incident is added to an asset, the asset's existing collection of downtime incidents is analyzed to determine if the new incident’s start date/time overlaps any of the existing downtimes’ start date/time and end date/time.
When adding new downtime incident to an asset which has thousands of previous incidents, the addition of a new one will be very slow due to the volume of validations taking place.
In APM Version 7.12.1, we introduce the ability to bypass this logic check.  New Setting:
In APM Help - Allowing Overlapping Downtime Incidents
DevOps - Work item 176206 - workaround to bypass the validation
DevOps - Bug 281640  - to fix the speed if validation bypass is not used
SR - 7000987457
