| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | 7.x | ||
| Area: | N/A | ||
| Subarea: | N\A |
Frequent user disconnects and the following error in the server log:
2017-04-07 07:42:44.9436 Error user Ivara.OTAssert [34] File: database.cpp(3074) : Failed Assert: Database Connect Error:
DBErrorType = 'dbConnection'
Native SQL Code = -1
ODBC sqlstate = 08S02
ODBC errortext = '[Microsoft][ODBC Driver 11 for SQL Server]SMux Provider: Physical connection is not usable [xFFFFFFFF]. '
ODBC errortext = '[Microsoft][ODBC Driver 11 for SQL Server]Unable to open a logical session'
2017-04-07 07:42:44.9436 Error user Ivara.OTAssert [34] File: database.cpp(2921) : Failed Assert: Database Statement Error:
DBErrorType = 'dbStatement'
Native SQL Code = 0
ODBC sqlstate = S1010
ODBC errortext = '[Microsoft][ODBC Driver Manager] Function sequence error'
2017-04-07 07:42:47.0808 Error user Ivara.OTAssert [34] File: database.cpp(3074) : Failed Assert: Database Connect Error:
Native SQL Code = 0
ODBC sqlstate = 08S01
ODBC errortext = '[Microsoft][ODBC Driver 11 for SQL Server]Communication link failure'
Recommended by Amazon Team that disable the TCP Chimney Offload
Disable the below settings in Local network connection à Network adapter properties.
And also disable below settings from Command prompt:
| Original Author: | Giselle Crawford |
