Handheld unexpected error occurred in IvaraMobile.exe
Product(s):
APM Implementation and Performance Management
Version(s):
R6+
Installed IvaraMobile on a HandHeld device and get the following error when attempting to launch the application:
An unexpected error has occurred in IvaraMobile.exe.  Select Quit and then restart this program, or select Details for more information.
Error IvaraMobile.exe TypeLoadException
Programs in storage memory:
SQLServerCompact 3.5 Core
SQLServerCompact 3.5 Repl
SQLServerCompact 3.5 Tools EN
Bentley Systems, Incorportated IvaraM...
 Windows Mobile version:
Windows Mobile 6.5
.Net Compact Framework 3.5 needs to be installed, perhaps this version of windows doesn’t come with it.
***It needs to be installed first before SQLCe and IvaraMobile.net
The instructions in the Install Guide – Setting up handheld Computing section, look at Setting up Handheld Computers topic
The Guide found on your Server install in C:\Program Files\Bentley\I<install dir>\Docs\English\Technical_Guides
