| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | N\A | ||
| Area: | N/A | ||
| Subarea: | N\A |
APM has extensive logging capability, with hundreds of logging categories. Most logging categories are not activated, for reasons of performance, disk utilization, as well as log file readability.
Should you need to add an additional logging category, for problem investigation, you may wish to log the messages to a log file separate from the default "file" target. This may simplify perusal of the log file.
All things "logging" are accomplished from the APM Settings Editor.
For Server, Thick-Client, APM Server Manager, and Remote instances, the Settings Editor is accessible from the APM Configuration utility, by way of the Configuration button's Full Settings option.
If running a Server instance in console mode, the Settings Editor is available on the APM Server dialog's Options menu, using the Server Settings menu option.
For a currently executing smart-client or thick-client, the Settings Editor is also available from the task tray's APM icon, by clicking with the right-mouse button, and selecting the Settings option.
You may want to have the smart-client, thick-client, and server instance setting readily available, without a running instance. To to this simply add the "-s" argument to an instance's shortcut.
HINT: You can log to multiple targets. You may want to log to the new target, plus the "file" target. Logging to both allows perusal of the logged messages isolated to the new target, without the clutter of other logged messages. Logging to the "file" target allows you to see the logged messages mixed with all other "file" target messages, should you wish to also see the messages in context of other log categories.
Debugging Remote Synchronization problems
Debugging Report Design problems
Debugging ODC collection problems
Debugging problems with Checksheet Processing of Indicator Readings
Profile Database Query Performance
Investigating Performance of Site Views
| Original Author: | roy suthers |
