Oracle - Invalid Stored Procedure need to be recompiled
 Version(s):6+
 Environment:N\A
 Area:N/A
 Subarea:N\A
The following query return records (invalid Stored Procedures)
select owner, object_name, object_type, status from all_objects where owner = 'OQ' and status <> 'VALID';
 Examples:
OQ.ENBL_ASSET_FNL_POSN_CONSTR Site
OQ.HIERARCHY_PATH_BUILDER Asset
OQ.UPD_INSTLD_CMPNTS_FUNCPOSITION Asset •         OQ.UPDATEINDICATORACCUMULATOR Indicator •         OQ.BUILDINDICATORHIERARCHY Indicator
The above will be affected when deploying customizations on Asset.
Adding a column, altering or rebuilding an index, will cause stored procedure to become invalid if these changes are to dependencies of the stored procedures .
Detect:
OR
SELECT COUNT(*) FROM dba_objects WHERE status = 'INVALID'; --it will give count of invalid objects.
SELECT object_type, count(*) from user_objects where status = 'INVALID' group by object_type;
SELECT owner, object_type, object_name FROM all_objects WHERE status = 'INVALID'
•DBA_OBJECTS : All objects in the database
•USER_OBJECTS : All objects owned by the user
•ALL_OBJECTS : All objects owned by the user and on which the user has been granted privileges
Fix:
Run proc_apponly_ivara.sql and proc_common.sql found in the Oracle directory on the application server.  This will recompile all stored procedures.
Issue 079913 created.
XXXXXXX(Add more links as needed for other relevant Be Communities content.)XXXXXXX
 Original Author:Giselle Crawford
