| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | 7 | ||
| Area: | N/A | ||
| Subarea: | N/A |
User found that the Indicator Reading of a Multiple Measurement Point Indicator entered via APM Mobile Inspections was being attribute to the Checksheet's employee and not the employee logged into APM Mobile Inspections.
Reported as bug, VSTS#957878.
The workaround is to use “Correct reading” to update the “Collected by” for Indicators where the reading is misattributed or to update the checksheet’s “Collection assigned to” in advance of the checksheet being processed.
SR 7001449087
