| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | 7 | ||
| Area: | N/A | ||
| Subarea: | N/A |
An APM user noticed that after an end-user's smart client crashed, later on the smart-client services would eventually stop allowing some end-users to log on the the APM smart client, even though the service appears to be running. The end-users receive an error message indicating that the service is down but the server manager will show that the service is still running.
The root-cause of the initial crash is under investigation. Sometimes objects are missing critical data, when those objects are accessed either by opening the object or launching a configuration or dashboard that configured to display or access that broken data, the client will crash. In these cases, because the crash is not a clean exit for the smart client, prior connections and app-locks can lead to a user reconnecting to the failed session. These issues should be reported to support for investigation and ADPlus set-up in order to determine the root-cause of the event so that the data can be corrected.
The workaround is to restart the smart-client services to clean any bad sessions and associated applocks.
