The following product features have the availability status "Available" as of the APM 26.0.0 release. They are functionally complete and have been fully tested. A feature must be manually enabled at the enterprise level before you can use it in APM.
Number |
Feature |
Description |
000143 |
Create Failure from a Request for Work |
This feature introduces the ability to create a Failure Event from a Request for Work. |
000142 |
Synchronize open checksheets with standard task updates |
This feature introduces the ability to have open checksheets automatically updated when the source standard task is updated. Based on the work type, the following changes are immediately applied to the standard task's open checksheets:
000141 |
Optimal cost calculation for Failure Finding Interval |
This feature introduces a new optimal cost Failure Finding Interval calculation. It calculates the optimal inspection interval based on the cost of a functional failure, the failure-finding cost, and the MTBF of the protected equipment and protective device. The optimal cost calculation is part of the failure-finding interval calculator for a failure mode. |
000140 |
Design FMECA |
This feature introduces the design FMECA as a new strategy development analysis. It is typically performed while a project is in the design stage. Its purpose is to identify potential failure modes while still in the design stage of a project. |
000139 |
Reminders and assignments |
This feature introduces the ability to create simple reminders for APM objects. Each reminder has a title, due date, owner (responsible employee), and status. Statuses, types, and priorities are user-defined value lists. A reminder has one or more assignments. An assignment identifies the employee responsible for completing the task, due date, title, and status. |
000138 |
Provide visibility to the user who initiated the processing of data loader updates |
This feature improves the quality of the audit records when objects are updated by a data loader or other process that imports from Excel. Previously, the user recorded on the audit record was the user assigned to the server where the process was executed. Now the audit record shows the user who initiated the process. |
000137 |
Asset hierarchy risk summaries |
This feature expands on the Asset Risk Summaries by providing the risk summary values for an asset and its descendants. The same information is available on the hierarchy summaries as on the asset summaries. However, the hierarchy summaries reflect the risk for the asset and its descendants. |
000136 |
Asset comparison |
This feature introduces the ability to compare the information for two assets. A variety of information is available for comparison and is organized around the asset-focused UI concepts of reliability focus, integrity focus, and asset health focus. The function includes the ability to identify filters to limit the assets to be compared. The same filtering capabilities available with asset health reports are available for asset comparisons. |
000135 |
Indicator template improvements |
New indicator template functions. This feature introduces the following functions for indicator templates:
000134 |
Ability to import Risk Evaluation values from a spreadsheet for analysis failure modes |
This feature introduces the ability to export a list of the failure modes on an analysis to Excel, enter the evaluation values in the spreadsheet, and then import the data back into the analysis. After importing the data, you can perform the evaluations by applying the data. |
000132 |
Asset-focused UX |
This feature introduces four new site and asset views: Reliability Overview, Integrity Overview, Safety Overview, and Degradation Overview. The first three of three of the overviews are focused on your assets and have the following characteristics:
The degradation overview is only available on assets that support degradation tracking. It provides one place to view the asset's degradation indicators and related information. The following information is available for each degradation indicator:
000131 |
Provide the ability to limit the priorities that can be used by work type |
This feature introduces the ability to limit the work priorities that can be selected based on work type. The filtering of work priorities based on work type is available in the following places only:
000128 |
Enforce indicator bar code scanning based on the standard task |
Enforce indicator bar code scanning based on the standard task. This feature introduces the ability to require indicator bar code scanning based on the checksheet's standard task. A new setting has been added to the standard task. The setting has three values:
The setting is copied to the checksheet where it can be overridden. |
000127 |
Update checksheet status when work status is updated |
This feature introduces the ability to synchronize checksheet status with the status of its Interop work order. Identify the checksheet status for each work status you want synchronized. When the work order's work status is updated, the system will update the checksheet status to the status identified on the work status. |
000126 |
Support ability to reset indicator degradation when piping replaced |
This feature introduces the ability to resent an indicator's degradation rates when a section of piping is replaced. Readings entered after the degradation is reset use the new values to calculate degradation rates, next inspection date, and end of life. |
000123 |
Inspection factor lookup based on integrity group, degradation, criticality, and confidence factor |
This feature provides the ability to extend the 3-dimensional inspection factor matrix to a fourth dimension, integrity group. This new capability allows you to define the Inspection Factor, Inspection Strategy, and Inspection Interval based on degradation type, criticality, confidence factor, and integrity group. Integrity group is identified on asset types, allowing an easy mechanism to group similar assets. For example, integrity groups can be created for piping systems, vessels, and heat exchangers. |
000122 |
Standard task solution package data loader |
This feature introduces a new Standard Task Solution Package data loader. The data loader allows solution package references, including the four solution package references and cycle to be loaded for one or more standard tasks. The data loader is included as part of the Reliability Management data loaders on Enterprise. |
000121 |
Asset risk summaries |
This feature introduces the ability to track risk summaries at the asset level. Risk summaries are based on the asset's failure modes and critical evaluation. Three sets of risk summaries are supported:
000120 |
Asset characteristics pivoted data loader |
This feature introduces a data loader for asset characteristics. It allows up to 50 characteristic values to be loaded for a single asset and characteristic class |
000119 |
Solution package identification on standard task |
This feature introduces the ability to identify the solution packages to reference on a checksheet's request for work. |
000118 |
Checksheet splitting |
This feature introduces the ability to split the readings on a checksheet across two or more checksheets. |
000117 |
Ability to defer standard task next due date calculation until inspection is complete |
This feature introduces the ability to defer the calculation of the standard task's next due date until its open checksheets are completed. |
000115 |
Practical RBI - criticality evaluation calculations |
This feature introduces the ability to automate the process of analyzing a failure mode's criticality through the use of lookup tables and delivered calculations. The ability for the user to define their own custom calculations is also supported. |
000114 |
Ability to identify start and end locations on a video on indicator and measurement point reading |
This feature introduces the ability to identify one or more videos to a checksheet. Once the videos have been linked to the checksheet, the locations on the video where an anomaly can be seen can be identified on individual readings. Inspection videos are typically used in places where inspectors cannot access the equipment or structure themselves and an unmanned vehicle is used. |
000113 |
Support for drilling platform asset specifications |
This feature introduces support for asset properties related to oil drilling platforms. |
000112 |
Support for the ability to add readings to a checksheet based on the value of a reading |
This feature introduces the ability to have additional conditional readings added to a checksheet based on the state entered for a reading. For example, if an indicator is in alarm, additional checks or readings need to be taken. These additional readings are only required if the first reading is in alarm. With this feature, you can identify the conditional indicators as part of the indicator state properties. |
000111 |
Solution package data loader |
This feature introduces two new data loaders for solution package tasks. The first allows the standard tasks associated with a solution package to be created or updated. The second allows task templates associated with a solution package template to be created or updated. |
000110 |
Indicator due date data loader |
This feature introduces a new Indicator Due Date data loader. The data loader allows new due dates to be loaded for one or more indicators. |
000109 |
Prevent redrafting of a checksheet based on the checksheet status |
This feature introduces the ability to control the availability of the redraft method based on the checksheet status. |
000108 |
Anomaly risk assessment |
This feature introduces the ability to integrate APM with an Anomaly Assessment and Tracking (AA&T) system. |
000107 |
Calibration template support |
This feature introduces the ability to define calibration templates. Calibration templates can be used to provide default values for a checksheet subtype. Currently, five subtypes are supported to enter calibration details on a checksheet: Ultrasonic calibration, Radiography calibration, dye penetration inspection, magnetic particle inspection, and eddy current inspection. Calibration templates can be created for each subtype. |
000106 |
Option to limit an asset status change to the current asset only |
This feature introduces the ability to limit an asset status change to the current asset only. The status of the asset's descendants is not updated. |
000105 |
Support the ability to update the warehouse item's storage locations when entering a count |
This feature introduces the ability to correct the warehouse item's inventory storage locations when recording a count. The warehouse item's locations are updated when the resulting adjustment transaction is posted. |
000104 |
Support for displaying asset PI&D or other document as part of the asset specifications |
This feature introduces the ability to display an asset document as part of the asset's specifications. The document displayed can be any document linked to the asset and can be a PDF, graphic image, Word document etc. |
000103 |
Support for Platform Inspection subtypes on Measurement Point Readings |
This feature introduces the ability to record information related to platform inspections. It controls access to the following subtypes for measurement point readings: ·Platform general visual inspection |
000102 |
Support structural minimum thickness when calculating an asset's minimum thickness |
This feature expands the existing minimum thickness calculation function to include support for Structural Minimum Thickness. |
000099 |
Support for reliability projects |
This feature expands the functionality associated with projects to allow the different types of analyses and other objects to bel linked to a project. The types of objects that can be linked to a project are:
000098 |
Support for project tasks |
This feature introduces the ability to identify tasks to be performed for a project. Project tasks provide a simple method of identifying tasks or actions to be performed without requiring the use of work orders or tasks. Project tasks have a limited set of properties and are not meant to replace work orders and tasks in cases where work planning is required. |
000097 |
Support site filtering rules of analysis team members |
This feature introduces the ability to control the employees who can be selected as team members. The new settings allow you to allow employees from:
These options apply to team members on a strategy development analysis, asset prioritization analysis, asset condition analysis, and RCA. |
000096 |
Support for Dead Leg Piping section asset specifications |
This feature introduces the ability to define properties related to a dead leg piping sections on an asset's specifications. |
000095 |
Support for Fabric Inspection subtype on Measurement Point Readings |
This feature introduces the ability to record information related to fabric or structure inspection for an oil drilling platform. |
000093 |
Support for Oil Drilling Platform asset specifications |
000092 |
Publish indicator readings to an external system |
This feature introduces the ability to publish indicator readings to an external system such as SAP or Maximo. |
000091 |
Support for Oil and Gas asset specifications |
This feature introduces support for asset properties related to the oil and gas industry. |
000090 |
Support display of an indicator's measurement point values in a grid format |
This feature introduces the ability to display an indicator reading's measurement point values in a grid format. |
000089 |
Standard task due date data loader |
This feature introduces a new Standard Task Due Date data loader. The data loader allows new due dates or proposed due date to be loaded for a standard tasks. |
000088 |
Maintenance action plan corrective task data loader |
This feature introduces a new maintenance action plan inspection task data loader. The data loader allows corrective tasks and corrective solution packages to be loaded for maintenance action plans. |
000087 |
Maintenance action plan inspection task data loader |
This feature introduces a new maintenance action plan inspection task data loader. The data loader allows inspection tasks to be loaded for maintenance action plans. |
000085 |
Asset prioritization and condition analyses data loaders |
This feature introduces two new data loaders to the APM collection of data loaders: Asset prioritization analysis data loader and the asset condition analysis data loader. |
000084 |
Create checksheet from Interop work orders' and work requests' recommendations from events |
This feature introduces the ability to create a checksheet based on the recommendations from event on both Interop work orders and work requests. Solution packages are not required to generate the checksheets. |
000083 |
Ability to create a checksheet from a Task Template |
This feature introduces the ability to create a checksheet directly from a task template. |
000082 |
Allow Interop Work Order and Interop Work Request to be manually set on a checksheet |
This feature allows users to manually select the source Interop Work Order and Interop Work Request on a checksheet. |
000081 |
Data loaders for degradation rates |
This feature introduces two new data loaders: Asset degradation rate data loader and Indicator degradation rate data loader. |
000079 |
Data loader for Measurement Point readings |
This feature introduces a new data loader for Measurement point readings. |
000078 |
Approvals support for requests for work |
This feature introduces support for approvals for Requests for Work. |
000077 |
Support for Interop work document change requests |
Work document change requests are used to request changes to an Interop Work Order or Interop Work Request. A change request can request:
Change requests can also request that any of the user flex fields be updated. The user flex fields consist of 10 string fields, 5 date fields, 5 check boxes, and 5 reference numbers. |
000076 |
Support for asset links |
This feature introduces the ability to link 1 to 5 assets to another asset. For example, in a electrical distribution network, the network protector and network switch can be linked to their transformer. |
000075 |
Support for user asset specifications |
This feature provides the ability to extend an asset's information through the use of User Asset Specifications.
000074 |
Support for type of inspection evaluation as part of the failure mode RBI analysis |
This feature introduces a new step in the RBI Analysis process: the type of inspection analysis. Type of inspection analysis is performed after the confidence analysis. The results of the type of inspection can identify if an internal, external, in-service or out of service inspection is required. |
000073 |
Support for circuit assets |
Ability to link circuits and the assets on a circuit. A circuit can identify things like an electrical circuit or corrosion loop.
On assets included on a circuit, you can view the list of circuits that asset is a part of.
The Circuits tab on the site's assets view shows you a list of all the circuits at a site. The same level of information is displayed for each circuit as on the asset's Circuits view.
000069 |
Ability to link checksheets and Interoperability work requests |
This feature introduces the ability to link an Interop work order's checksheets to Interop work requests related to the work order. |
000068 |
Support for follow-up requests for work |
This feature introduces the ability to generate a request for work based on the completion of a interop work order or work request. |
000065 |
Display asset properties on selected objects |
This feature provides the ability to display a set of asset properties on the following objects:
When the feature is enabled, you are able to define at the asset type level on which objects you want asset properties displayed and the panel to use. An Asset Properties view (on checksheet) or page (Indicator Reading and Request for Work) is added to the user interface if the asset's asset type has enabled support for displaying asset properties. |
000064 |
Ability to restrict the priorities used on a work request based on the maintenance group |
This feature provides the ability to define the available work priorities based on the maintenance group assigned to a request for work. |
000063 |
Ability to make the creation of the work document mandatory on an indicator reading |
This feature introduces the ability to make the creation of a work document (request for work) mandatory based on the indicator state. This feature expands on the existing ability to create a work document as part of an indicator reading by making the creation of the work document mandatory. |
000062 |
Distribution Network work information on AssetWise Interoperability work documents
This feature extends the information supported on AssetWise Interoperability work documents. The information includes properties related to working on electrical equipment in an urban area. This includes:
Distribution network information is available for entry on a request for work, when acknowledging an alarm, creating a work document as part of an indicator reading, follow up work requests and other places where work can be initiated in APM. The information is also visible on Interop work requests, Interop work orders and solution packages. |
000061 |
Regulatory reporting tracking support on assets |
This feature introduces the ability to track regulatory reporting information on assets
If regulatory reporting is supported, you can identify by the type of asset. |
000060 |
Collector's note mandatory based on type of alarm and marking asset as unavailable for reading |
Ability to make it mandatory to enter collector's notes on manually-entered indicator readings, based on the alarm type or if the asset is unavailable for reading. This feature is generally available. |
000058 |
Notes support |
Notes or asset notes allow notes to be added to a number of APM objects. See the list below.
Optionally, a note can be reviewed. Reviewing a note allows a user to respond to the original note. The note type controls whether review is supported for a note.
000057 |
Default approval route support |
Ability to identify a default approval route to use when an approval request is created. |
000056 |
Review or approval support for Asset Change Requests |
This feature introduces the ability to implement the review or approval process for asset change requests. Asset change requests only apply when Bentley AssetWise Interoperability has been implemented.
000055 |
Ability to request changes to asset properties outside of a construction form |
Asset change requests were introduced as part of Construction Management. They are used to communicate information to the external CMMS that owns assets. The asset update is performed in the CMMS and the resulting asset update request is then communicated to APM.
000054 |
Fluid condition tracking and results |
This feature allows you to enable the APM Fluid Condition function. Fluid Condition allows you to export and import fluid samples to a Fluid Analysis Lab and record the results on a Fluid Condition checksheet. Enabling the feature allows you to:
000053 |
Fluid sample support |
This feature allows you to enable the ability to record information pertaining to a fluid sample on an Indicator Reading. Enabling the feature allows you to:
When the feature is disabled, the fluid sample properties on indicator type, indicator, indicator state and reading are hidden. |
000052 |
Remove overrides from a task template's standard tasks |
Support the ability to remove the overrides from Standard Tasks based on a Task Template. This feature is generally available. |
000051 |
Support generation of checksheets for standard tasks without requiring a work order |
Support the Generation of Checksheets for standard tasks |
000050 |
Support ability to limit the duration that is scheduled for a work order task |
Support the ability to limit the duration scheduled per shift for a work order task I would like to see an enhancement made to the system so that a work task can be flagged or limited so that it will only schedule a portion of the hours for a shift and if possible, it would schedule it on consecutive days for the same number of hours until the hour requirement is met. When the feature is enabled, you are able to identify that the work is to be limited to a set duration when it is scheduled. The scheduling limit can be defined on a standard task and is copied to the work order task. The limits can also be defined directly on the work order task. |
000049 |
Link an acknowledgment to a work document with AssetWise Interoperability |
This feature allows you to acknowledge an indicator alarm by referencing an existing Request for Work, Interop Work Request, or Interop Work Order. When an alarm is acknowledged with an existing work document, a new Request for Work is not created. No information is passed to the CMMS. The link to the existing work document remains known to APM only. It is assumed the user knows that the scope of the existing work addresses the new alarm.
000048 |
Support for user defined fields on AssetWise Interoperability Work Documents |
Support for user-defined fields with AssetWise Interoperability
When the feature is enabled, you are able to identify the user fields to be used and name each of the used fields. Additionally you are able to identify if any of the used fields are mandatory or read only by work type and site. |
000046 |
Failure codes support with AssetWise Interoperability |
Support for additional failure codes with AssetWise Interoperability
When the feature is disabled, Object part, damage codes and activity codes are used. |
000042 |
Support for critical parts identification on a maintenance action plan |
Critical Parts Analysis on a Maintenance Action Plan
Critical parts can be identified on all types of strategy development analyses, including templates. |
000039 |
Criteria based probability evaluation on an asset prioritization analysis |
Criteria-based probability of failure evaluation as part of an asset prioritization analysis
When this feature is enabled, you are able to identify the method used to analyze the probability of failure. The two supported methods are by selecting the probability of failure from a list of probabilities or performing a formal analysis. |
000036 |
Updating existing data to be ready for use with AssetWise Interoperability |
Updating data to be ready for AssetWise Interoperability |
000034 |
Advanced production loss accounting |
When this feature is enabled, you are able to identify the production loss accounting level as basic or advanced for each site. Basic production loss accounting is based on downtime incidents and a single product per asset. |
000033 |
Hierarchy recursion support for exports |
Hierarchy Recursion Support on Reports This feature enables the ability to define reports with hierarchy recursion support, for example, a list of Requests for Work for an asset and its descendants or a list of Requests for Work for a site and its ancestors. This feature is generally available. |
000032 |
Integration with 4D Analytics |
This feature enables the ability to integrate APM with 4D Analytics system. |
000028 |
Asset change requests |
The objects associated with asset change requests include:
000027 |
Asset program profile |
Asset Program Profiles
Asset program profiles can be created from the Assets view, Program Profiles tab. Asset programs can be manually generated from assets, asset program profiles, and the site. |
000024 |
Allowing work orders with multiple assets to be sent to SAP |
Allow work orders with multiple assets to be sent to SAP |
000023 |
Asset characteristics |
Asset Characteristics Support
The objects associated with asset characteristics include:
000022 |
Construction management |
Construction management is a view on both site and asset. |
000021 |
Regulated gas management |
Regulated Gas Management
Regulated gas management is a view on both site and asset. |
000017 |
Data loader for user site security profiles |
This feature consists of a new data loader for User Site Security Profiles. |
000013 |
Additional data loaders for the Reliability Program |
This feature consists of an additional set of data loaders for the Reliability Program. It includes data loaders for the following:
When enabled, this feature can be accessed from the Data Loaders view on Enterprise under the Reliability Program tab. |
000009 |
Time zones by site |
Time Zones by Site |
