Terminologies used in Amulet.
Product(s):AssetWise Operational Analytics (Amulet)
Version(s):AMR 36
Area:
Problem :
What are the different terminologies used in Amulet?
Solution :
Listed below are most of the terminologies used in Amulet, with their description :
  1. Generic and Process Parameters behave in the same way but have a different icon – there is no other difference. Generic and Process Parameters store the raw data.
  2. Calculated Parameters allows users to configure calculations. Their data comes from the results of the calculations.
  3. XY Points are used to represent assets such as a pipeline (distance at points along the pipeline for example) where there are multiple readings per timestamp. Not used very often as there is a very limited set of widgets to display the data.
