Moving a checked out license from one computer to another
- If you need to move/relocate a checked out license to another machine, you will need to check-in the license from the current machine so that it's available for check-out again to the new machine.
- Steps to check-in license from one computer to another: you can send this to users
1. Each computer will have to be connected to the internet during this process
2. On the current computer, open the License Management Tool
- From MicroStation/PowerDraft: Open any file, then go to Utilities > License Management Tool
- Or from Windows Start Icon > Programs > Bentley > Name of Bentley software > License Management Tool
3. Select the "License Checkout" tab (for older versions this is the default window)
- In the bottom list, click on the software for which you need to renew the license
- Then click on "Check-In"
- The product should now be visible in the top list, with at least 1 license available
4. With the same method, open the License Management Tool on the new computer
5. Select the "License Checkout" tab (for older versions this is the default window)
- The product needed should be visible in the top list, with at least 1 license available
- Click on the product in the top list
- Then click on "Check-Out"
- The product should now be visible in the bottom list, with at new expiry date
NOTE: If either of the computers do not have an internet connection, you will have to contact your Site Administrator and ask him/her to force the license check-in and provide a XML license file for the new computer.
1.SELECT Activation process for XM and V8i products (versions 08.09.xx.xx and up)
2.SELECT Activation process for pre-XM products (versions 08.05.xx.xx and lower)
3.SELECT Activation process for a machine NOT connected to the internet
4.Software is in "Disabled" mode (15 minute mode)
5.Software is in "Trial" mode (30 day trial)
6.Software is in "Offline" mode
7.Software is in "Expired" mode
8.Pre-XM version via Gateway opens in trial mode (Gateway problems)
9.User is using an incorrect activation key
10.Checked out license has expired / will expire in 30 days
11.License is checked out to a machine that has crashed
12.Moving a checked out license from one computer to another
13.Activation is being attempted for wrong product
14.Activation key has not been received / has been lost
15.Activation key is faulty
16.Computer cannot communicate correctly with Bentley server (Activation Key does not verify)
17.Incorrect activation entry to the Registry
18.User wants list of licenses associated to his/her account
