Note: If a user has recently gone from a SELECT Contract to a Non-SELECT Contract and cannot Check-Out a License for more then 30 days against PRODUCTACTIVATION.BENTLEY.COM then try and activate/Check-Out against SELECTSERVER.BENTLEY.COM. Mostly likely the account information has not been correctly updated somewhere in the back-office.
To check this login in to https://connect.bentley.com/ > License Management and check to see what HOSTED SERVER INFORMATION the Account ID is assigned to. If the Account ID should be NON-SELECT but the HOSTED SERVER INFORMATION says SELECTSERVER.BENTLEY.COM then use that to activate against.
If it still wont activate/ Check-Out a License for more then 30 days then clear the Licensing in the Registry and try again. http://communities.bentley.com/products/licensing/w/selectserver_and_product_activation_wiki_-_internal_only/incorrect-activation-entry-to-the-registry
1.NON-SELECT Activation process
2.NON-SELECT Activation process for a computer NOT connected to the internet
3.User is using an incorrect activation key
4.Activation is being attempted for wrong product
5.Activation key has not been received / has been lost
6.Checked out license has expired / will expire in 30 days
7.Moving a NON-SELECT license to a different computer
8.License is checked out to a computer that has crashed
9.Activation key is faulty
10.Computer cannot communicate correctly with Bentley server (Activation Key does not verify)
11.Incorrect activation entry to the Registry
12.User wants list of licenses associated to his/her account
13.Additional notes
