| Product(s): | All | ||
| Version(s): | All | ||
| Area: | Licensing | ||
| Subarea: | New order - Software Download and Licensing Information | ||
| Original Author: | Bentley Licensing Support Group | ||
| Date Logged | April 2016 | ||
I received the following attachment in an email from Bentley:
What do I do with this "Software Download and Licensing Information" email?
This email was sent due to a new order. The document contains key pieces of information to download and license this software mentioned within Highly suggest to read the entire document (typically 2 pages). After reading the document you should be able to find the following important information:
1. Software download link
2. Server Name
3. Site Activation Key
Software Download Instructions
If server name is selectserver.bentley.com, see Activating Against SELECTserver OnLine (a Bentley hosted server)[TN]
If server name is 'Your Site Administrator will provide this', see Activating Against a Locally Deployed SELECTserver [TN]
If server name is productactivation.bentley.com, see Activating as a NON-SELECT or Node Locked user [TN]
Activation
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
