Software is in "Trial" mode (30 day trial)
Software is in "Trial" mode (7 resp. 30 day trial)
1.SELECT Activation process for XM and V8i products (versions 08.09.xx.xx and up)
2.SELECT Activation process for pre-XM products (versions 08.05.xx.xx and lower)
3.SELECT Activation process for a machine NOT connected to the internet
4.Software is in "Disabled" mode (15 minute mode)
5.Software is in "Trial" mode (30 day trial)
6.Software is in "Offline" mode
7.Software is in "Expired" mode
8.Pre-XM version via Gateway opens in trial mode (Gateway problems)
9.User is using an incorrect activation key
10.Checked out license has expired / will expire in 30 days
11.License is checked out to a machine that has crashed
12.Moving a checked out license from one computer to another
13.Activation is being attempted for wrong product
14.Activation key has not been received / has been lost
15.Activation key is faulty
16.Computer cannot communicate correctly with Bentley server (Activation Key does not verify)
17.Incorrect activation entry to the Registry
18.User wants list of licenses associated to his/her account
