| | Product(s): | SELECTserver | |
| | Version(s): | 08.11.07.111 | |
| | Environment: | N\A | |
| | Area: | Installation / Configuration | |
| | Subarea: | N\A | |
| | Original Author: | James White, Bentley Technical Support Group | |
Technical Requirements
Bentley recommends taking advantage of a Bentley-hosted SELECTserver.
Installation Requirements
Supported Operating Systems - SELECTserver
• Microsoft Windows 2003 Server Web Edition (SP2) (including 64 bit)
• Microsoft Windows 2003 Server Standard Edition (SP2) (including 64 bit)
• Microsoft Windows 2003 Server Enterprise Edition (SP2) (including 64 bit)
• Microsoft Windows 2003 Server 2003 R2 (SP2) (including 64 bit)
• Microsoft Windows 2008 Server (SP2) (including 64 bit)
• Microsoft Windows Vista Enterprise, Ultimate, Business (SP2) (including 64 bit)
• Microsoft Windows 2008 R2 (SP1) Server All Additions
• Microsoft Windows 7 (SP1) All Additions
NOTE: Installing SELECTserver on a Domain Controller is not supported.
Small Business Servers (SBS) contain Domain Controllers and are not supported
Supported Operating Systems - SELECTserver Gateway Service
• Microsoft Windows XP Professional (x86 SP3) (x64 SP2)
• Microsoft Windows Vista Home, Home Premium (SP2) (including 64 bit)
• Microsoft Windows 2008 R2 Server (SP1)
Supported Browsers
· Microsoft Internet Explorer v8.0 or later
Supported SQL Server Databases
· SQL Server 2005 All Editions including Express
· SQL Server 2008 All Editions including Express
· SQL Server 2008 R2 All Editions including Express
Note: SQL SERVER 2000 and MSDE are no longer supported.
Software Prerequisites - SELECTserver requires:
· Internet Information Servers (with ASP.NET support)
Software Prerequisites - SELECTserver Gateway requires:
· Microsoft .Net Framework 2.0
· MSXML 6.0
Note: The current SELECTserver Gateway installer does "NOT" put these prerequisites in place. Please ensure their presence before installation.
Software Installed with SELECTserver:
The following software is installed with SELECTserver if it is not already installed.
• Windows Installer 4.5
• Microsoft .Net Framework 4.0 (A reboot may be required)
• MSXML 6.0
• SQL Server 2005 Express if selected (A reboot may be required)
Note: The server may have to be rebooted one or more times in order to complete the installation any of the above components
Minimum System Recommendation
· 4GB RAM
· Pentium 4 Or Higher
· 4 GB of Free Disk space
External Links
