| Product(s): | Multiple | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
When licensing a pre-XM application with a standalone Nodelock license file, the license file should be delivered from Bentley with the correct file name. Copy the attachment to the appropriate directory. Once the license file is in place, launch the product and it should start.
If necessary, see below for a list of license file names and locations.
If you are running a pre-XM application with server-based licensing, please refer to Pointer Files Explained for Pre-XM Products, before proceeding.
Please note, if you are working on a 64-bit operating sytem, you may need to use Program Files (x86) in place of Program Files in the directory paths specified below. Most of these applications are not certified on newer operating systems. Please be aware that issues may arise when installing an older application on a newer operating system.
For Pre-XM applications older than 8.5, refer to License File Names 8.0 & Below for license file names and locations.
Foundation Products
Product |
License File Name |
License File Directory |
Select Servable? |
Bentley Parametric Cell Studio 2004 Edition |
psstudio.lic |
\Program Files\Bentley\Program\Licensing\ |
Yes |
Bentley PowerCivil 2004 Edition |
powercivil.lic
Yes |
Bentley Powermap Field 2004 Edition |
powermapfield.lic |
Yes |
Bentley PowerMap Field for Communications 2004 Edition |
powermapfield_communications.lic |
Yes |
Bentley PowerMap 8.1 |
powermap.lic
Yes |
Bentley PowerRebar |
powerrebar.lic |
Yes |
Bentley Redline |
bentleyrdl.lic |
Yes |
Bentley View |
bentleyview.lic |
ONLY! |
MicroStation V8 |
msv8.lic |
Yes |
MicroStation V8 XM Edition Beta |
msv8.lic |
C:\Program Files\Bentley\Licensing\ |
Yes |
MicroStation/J 7.1 |
msj.lic |
\bentley\program\licensing\ |
Yes |
CivilPAK, GeoGraphics, Modeler, Shematics, TriForma |
msj.lic |
Yes |
GeoGraphics (Old Versions) |
msgeo.lic or msjgeo.lic |
Yes |
MicroStation PowerArchitect 7.0 |
Pwrarch.lic |
Yes |
MicroStation PowerDraft v7.1 |
draft70.lic |
Not supported |
MicroStation PowerDraft V8 (& Bentley PowerDraft 8.1 & Bentley PowerDraft 2004) |
draftv8.lic |
Yes |
MicroStation PowerScope v7.1 |
scope70.lic |
Not supported |
PDF Composer |
composer.lic |
Used to obtain license outside of MicroStation |
Project Review |
prjreview70.lic |
Yes |
Select Server 7.4 and below |
license.lic |
\SELECTserver |
N/A |
Select Server 8.0 and up |
license.lic |
\ProgramFiles\SELECTserver |
N/A |
Building & Plant Engineering Products
Product |
License File Name |
Select Servable? |
Architecture for Triforma |
architecture.lic |
Yes |
Architecture for TriForma V8 |
architecture.lic |
Yes |
Bentley Architecture 8.1 |
architecture.lic |
Yes |
Bentley AXSYS.Engine 2004 Edition |
axengine.lic |
Yes |
Bentley AXSYS.Integrity 2004 Edition |
axintegrity.lic |
Yes |
Bentley AXSYS.Process 2004 Edition |
axprocess.lic |
Yes |
Bentley AXSYS.Server 2004 Edition |
axserver.lic |
Yes |
Bentley Building Electrical Systems |
electricalsystems.lic |
Yes |
Bentley HVAC 8.1 |
hvac.lic |
Yes |
Bentley Piping 2004 Edition |
bentleypiping.lic |
Yes |
Bentley Plant Portfolio - Physical Design (3D) for MicroStation v8.1 |
msv8.lic |
Yes |
Bentley Plant Portfolio - Physical Design (3D) for MicroStation v8.1 w/MicroStation |
msv8.lic |
Yes |
Bentley PlantSpace Equipment 2004 Edition |
tfeqmod.lic |
Bentley PlantSpace Equipment Modeler V8.1 |
tfeqmod.lic |
Yes |
Bentley PlantSpace HVAC 2004 Edition |
hvac.lic |
hvac.lic |
Yes |
Bentley PlantSpace HVAC V8.1 |
hvac.lic |
Yes |
Bentley PlantSpace IsoExtractor 2004 Edition |
isoextps.lic |
Bentley PlantSpace IsoExtractor V8.1 |
IsoExtPS.lic |
Yes |
Bentley PlantSpace Isometrics 2004 Edition |
liso.lic |
Bentley PlantSpace Isometrics V8.1 |
Liso.lic |
Yes |
Bentley PlantSpace Orthographics |
psorthographics.lic |
Bentley PlantSpace Orthographics 2004 Edition |
Bentley PlantSpace P&ID 2004 Edition |
pid.lic |
Bentley PlantSpace P&ID V8.1 |
pspid.lic |
Yes |
Bentley PlantSpace Piping 2004 Edition |
pspiping.lic |
Bentley PlantSpace Piping V8.1 |
pspiping.lic |
Yes |
Bentley PlantSpace Raceways 2004 Edition |
tfrace.lic |
Bentley PlantSpace Raceways V8.1 |
tfrace.lic |
Yes |
Bentley PlantSpace SupportManager 2004 Edition |
psSupManager.lic |
Bentley PlantSpace SupportModeler 2004 Edition |
pssupmod.lic |
Yes |
Bentley PlantSpace SupportModeler V8.1 |
pssupmod.lic |
Yes |
Bentley Structural 8.1 |
structural.lic |
Yes |
Electrical Elementary Diagrams |
eed.lic |
Yes |
Equipment Modeler |
tfeqmod.lic |
Yes |
HVAC Air Flow Diagram |
AFDANSI.LIC |
HVAC for MicroStation |
hvac.lic |
Yes |
HVAC for Triforma V8 |
hvac.lic |
Yes |
Interference Manager |
Ifmeng.lic |
Yes |
IsoExtractor |
isoextps.lic |
Yes |
L/ISO |
liso.lic |
Yes |
MicroStation Landscape |
msla.lic |
Yes |
Personal ISOGEN |
pisogen.lic |
Yes |
PlantSpace Instrumentation |
psinst.lic |
Yes |
PlantSpace P&ID |
pspid.lic |
Yes |
PlantSpace Piping Module |
pspiping.lic |
Yes |
PlantSpace Piping Module (DIN) |
pspipingdin.lic |
Yes |
PlantSpace SupportModeler |
pssupmod.lic |
Yes |
Raceways |
tfrace.lic |
Yes |
RAM Advanse |
RAM Concept Floors |
RAM Concept Mats |
RAM Concept PT |
RAM Concrete |
RAM Connection |
RAM Foundation |
RAM Frame |
RAM Frame Drift Control |
RAM Frame Seismic Provisions |
RAM Frame Standard Provisions |
RAM Modeler |
RAMModeler.lic |
\Program Files\Bentley\RAM\bin |
Yes |
RAM Steel |
RAMSteel.lic |
Yes |
Structural For Triforma V8 |
Structural forTriforma |
stf.lic |
Yes |
SupportModeler for PDS |
pssupmodpds.lic |
Yes |
Product |
License File Name |
Select Servable? |
Bentley InRail 8.4 & 8.5 |
bentleycivil.lic |
\bentley\civil\licensing\ |
Yes |
Bentley InRail 8.7 |
bentleycivil.lic |
\program files\bentley\inroads group\licensing\ |
Yes |
Bentley InRoads 8.4 & 8.5 |
bentleycivil.lic |
Yes |
Bentley InRoads 8.7 |
bentleycivil.lic |
Yes |
Bentley InRoads Bridge 8.4 & 8.5 |
bentleycivil.lic |
Yes |
Bentley InRoads Bridge 8.7 |
bentleycivil.lic |
Yes |
Bentley InRoads Site 8.4 & 8.5 |
bentleycivil.lic |
Yes |
Bentley InRoads Site 8.7 |
bentleycivil.lic |
Yes |
Bentley InRoads Storm & Sanitary 8.4 & 8.5 |
bentleycivil.lic |
Yes |
Bentley InRoads Storm & Sanitary 8.7 |
bentleycivil.lic |
Yes |
Bentley InRoads Survey 8.4 & 8.5 |
bentleycivil.lic |
Yes |
Bentley InRoads Survey 8.7 |
bentleycivil.lic |
Yes |
Bentley PowerSurvey v8.1 |
Powersurvey.lic & draftv8.lic |
Yes |
GEOPAK Bridge |
Geopak.lic |
Yes |
GEOPAK Civil Suite |
Geopak.lic |
Yes |
GEOPAK Rebar |
geopak.lic |
Yes |
GEOPAK Site |
geopak.lic |
Yes |
GEOPAK Survey |
geopak.lic |
Yes |
InRail 8.2 |
selectcad.lic |
\bentley\selectcad\licensing\ |
Yes |
InRail v8.3 |
bentleycivil.lic |
Yes |
InRoads Bridge v8.2 |
selectcad.lic |
Yes |
InRoads Bridge v8.3 |
bentleycivil.lic |
Yes |
InRoads Site v8.2 |
selectcad.lic |
Yes |
InRoads Site v8.3 |
bentleycivil.lic |
Yes |
InRoads Storm & San v8.2 |
selectcad.lic |
Yes |
InRoads Storm & San v8.3 |
bentleycivil.lic |
Yes |
InRoads Survey |
selectcad.lic |
Yes |
InRoads Survey v8.3 |
bentleycivil.lic |
Yes |
InRoads v8.2 |
selectcad.lic |
Yes |
InRoads v8.3 |
bentleycivil.lic |
Yes |
MX Network |
(s/n #).MXS |
You will be prompted to select your authorization code (.mxs file) while running the MX setup program.
To update the authorization code on an existing MX installations run Update your Software Authorization Code from the MX License Manager Program Group. |
MX Standalone |
(s/n #).MXS |
To update the authorisation code on an existing MX installations run MX Options from the MX Program Group and select New Authorization code. |
MX Standalone 2004 Edition |
mx.lic |
Any folder on the computer (?) |
Product |
License File Name |
Select Servable? |
Bentley CadScript |
Cadscript.lic |
Yes |
Bentley Digital InterPlot 8.1 |
None! |
Uses License Broker |
ONLY! 8.2 or later |
Bentley Digital InterPlot File Server 8.1 |
ONLY! |
Bentley Digital InterPlot Web Server 8.1 |
ONLY! |
Bentley Publisher 3.8 |
pub.lic |
\Bentley\Program\BentleyPublisher\pub.lic |
Bentley Publisher 8.1 |
None! |
ONLY! |
Bentley Model Streaming |
ONLY! |
Digital Interplot |
No |
License Broker (Service that points apps to Select Server) |
licbroker.lic |
\program files\common files\bentley shared\licensebroker |
Installed by PW application, no S/N needed, or available |
Product |
License File Name |
ActiveAsset Analyst 2.0 |
\bentley\Program Files\ActiveAsset Planner\bin |
ActiveAsset Asset Management Option V2.0 |
Not real product currently, in pricebook for quoting purposes |
ActiveAsset Inquirer 2.0 Base |
aaiclient.lic |
\java\JRun\servers\default\Inquirer-app\jsp\jni\ |
ActiveAsset Inquirer 2.0 (25 add'l user) |
aaiclient.lic |
ActiveAsset Modelbuilder |
\Bentley\Program Files\ActiveAsset Planner\bin |
ActiveAsset Move Manager |
ActiveAsset ODS-Editor |
ActiveAsset Planner 2.0 |
aap.lic |
ActiveAsset Reports |
Superset of the Reports Designer and Viewer Products |
ActiveAsset Reports Designer |
aar.lic |
\Program Files\ALNA\ActiveAsset Reports\bin |
ActiveAsset Reports Viewer |
aarv.lic |
ActiveAsset Roombook |
ActiveAsset Space Management Option V2.0 |
Not real product currently, in Pricebook for quoting purposes |
Bentley Facilities Manager 8.1 |
bfm.lic |
\bentley\Program FIles\Bentley Facilities\Planner\bin |
Bentley Facilities Planner 8.1 |
bfp.lic |
\bentley\Program Files\Bentley Facilities\Planner\bin |
Bentley Facilities Reports V8.1 |
bfr.lic |
\Program files\Alna\Bentley Facilities Reports/bin |
Product |
License File Name |
Select Servable? |
Bentley Geo Web Publisher |
Bentley WasteWater (8.1 & 2004) |
bww.lic |
Yes |
Bentley Water (8.1 & 2004) |
bw.lic |
Yes |
GeoSELECTools |
geoseltools.lic |
Yes |
GeoXpressions |
geoxpressions.lic |
Yes |
MicroStation GeoCoordinator |
gcoord.lic |
Yes |
MicroStation GeoDynSeg |
dynseg.lic |
Yes |
GeoExchange |
msj.lic |
Yes |
MicroStation GeoGraphics (Old) |
msgeo.lic |
Yes |
MicroStation GeoOutlook v7.1 |
geoolk70.lic |
Not supported |
Bentley Geopak v8.1 |
Geopak.lic |
Yes |
MicroStation GeoParcel |
msgp.lic |
Yes |
MicroStation GeoTerrain |
geopakgt.lic |
Not supported |
MicroStation GeoWasteWater |
msgeoww.lic |
Yes |
MicroStation GeoWater |
msgeow.lic |
Yes |
MicroStation Telco MicroStation Telco V8 |
msutelco.lic Telco.lic |
\bentley\program\licensing\ \bentley\program\licensing\ |
Not supported |
Imaging and Conversion Products
Product |
License File Name |
Select Servable? |
CloudWorx (AutoCAD) |
CLWXAP2.lic |
...\Program Files\Cyra Technologies\Cyclone\Bentley CloudWorx\ACAD 2000\ |
Yes |
CloudWorx (MicroStation) |
CLWX2.lic |
\Program Files\Cyra Technologies\Cyclone\Bentley CloudWorx\MicroStation v8\ |
Yes |
MicroStation Descartes v7.0 |
Dcartes.lic |
Not supported |
MicroStation Descartes v7.1 |
Dcartes.lic |
Yes |
MicroStation Descartes v8.0, v8.1 |
Dcartes.lic |
Yes |
MicroStation I/RAS B |
irasb.lic |
Yes |
MicroStation I/RAS B v8, v8.1 |
irasb.lic |
Yes |
Bentley I/RAS B 2004 Edition |
irasb.lic |
Yes |
ReproGraphics v7.0 |
repro.lic |
Not supported |
MicroStation ReproGraphics v7.1 |
repro.lic |
Yes |
Integration and Simulation Products
Product |
License File Name |
Select Servable? |
Bentley Navigator 8.1 |
navigator.lic |
Yes |
Bentley Navigator 2004 Edition |
navigator.lic |
Yes |
Dynamic Animator |
dynanimator.lic |
Yes |
Enterprise Navigator |
entnav.lic |
Yes |
ModelServer Integrator |
msint.lic |
Yes |
Schedule Simulator |
schsim.lic |
Yes |
CivilStorm , CulvertMaster , FlowMaster , GISConnect , HAMMER , PondPack , SewerCAD , SewerGEMS , StormCAD , WaterCAD , WaterGEMS
On the client machines, browse to the product directory - typically C:\Program Files\Haestad\Product_Name (where Product_Name is an abbreviation of the product name, eg. WTRC for WaterCAD) and open the file "license.lic" with a text editor such as Notepad. This file should contain the line SERVER="server name" (where "server name" is the name of the server running SELECTserver). Update this file if required,
then save and close it.
Plotting Products
Product |
License File Name |
Select Servable? |
None! |
See MSM Online, July 29, 2003 |
ONLY! |
Bentley Publisher |
ONLY! |
Digital InterPlot |
idi.lic |
\Program Files\Common Files\InterPlot\Licensing\ |
InterPlot Client |
ipcli.lic |
Yes |
Bentley InterPlot Client 2004 Edition |
ipcli.lic |
InterPlot Driver Pack |
ipdrvpck.lic |
\Program Files\CommonFiles\InterPlot\Licensing\ |
Not supported |
InterPlot Mid-Vol Drv Pack |
ipmvdpk.lic |
Not supported |
InterPlot Professional |
ippro.lic |
Not supported |
IPlot Raster Offline Drv Pack |
ipoffdrv.lic |
Not supported |
InterPlot Server |
ipsrv.lic |
Not supported |
IPlot Digital Print Room Wkgrp |
ipdprwg.lic |
Not supported |
Digital Print Rm Enter (12 limit) |
ipdpr12.lic |
Not supported |
Digital Print Rm Enter (unltd) |
ipdprunl.lic |
Not supported |
Product |
License File Name |
Select Servable? |
Bentley Connector for eWarehouse 2004 Edition |
ewh.lic |
\Bentley\Program\Licensing |
Bentley ProjectWise 8.1 |
None! |
Bentley ProjectWise Document Publisher 8.1 |
pwdp.lic |
\Program Files\Bentley\ProjectWise\License\ |
Bentley ProjectWise Markup Manager 8.1 |
None! |
Bentley ProjectWise Reports 8.1 |
Pwr.lic |
\Program Files\Bentley\Llicensing\ |
Bentley Universal Client License 8.1 |
None! |
Document Publisher |
pwdp.lic |
\program files\allaire\jrun\servlets |
Not supported |
licbroker.lic |
MarkUpManager |
pwmkp.lic |
\program files\bentley\pwserver\license |
N |
ProjectWise Database Synchronization 3.8 |
pwdbsynch.lic |
\USTATION\LICENSE - Note that this is an SE style license |
N |
ProjectWise Document Publisher V8 |
N |
ProjectWise Export/Import 3.8 |
pwimpexp.lic |
\Program Files\Bentley\PWExplorer\Bin |
Bentley ProjectWise Export/Import 2004 Edition |
pwimpexp.lic |
\Program Files\Bentley\ProjectWise\Bin |
ProjectWise Reports 3.8 |
PWR.LIC |
ProjectWise Server License |
pw.lic files |
Not supported |
ProjectWise Transmittal 3.8 |
pwtrans.lic |
\Program Files\Bentley\Program\Licensing |
Product |
License File Name |
Select Servable? |
Viecon.interchange |
interchange.lic |
Yes |
Viecon Publisher |
n/a |
\bentley\program\VieconPublisher |
ONLY! 7.3 or later |
Bentley Communication (some Former FOCUSOne) Products
Product |
License File Name |
Select Servable? |
Bentley Coax 2004 Edition |
Bentley_Coax.lic |
Yes |
Bentley Copper 2004 Edition |
Bentley_Copper.lic |
Yes |
Bentley Fiber 2004 Edition |
Bentley_Fiber.lic |
Yes |
Bentley Inside Plant 2004 Edition |
Bentley_Inside.lic |
Yes |
Bentley Licensed Former Rebis Products
The default licensing path will depend on your prior installation, if any, of AutoPLANT applications, and can be found in one of the following paths:
Product |
License File Name |
Servable? |
(PlantLIFE) Knowledge Manager 8.1 |
Knowledge.lic |
Bentley Knowledge Manager 2004 Edition |
Knowledge.lic |
2D Piping 2.0x |
2Dpiping.lic |
2D Piping 3.0x |
2Dpiping.lic |
3D Electrical |
3DElect.lic |
AutoISOGEN PLUS 2.0x |
AutoISOGENPL.lic |
Not supported |
AutoISOGEN PLUS 3.0x |
AutoISOGENPL.lic |
Not supported |
Bentley AutoPLANT AutoISOGEN PLUS 2004 Edition |
AutoISOGENPL.lic |
AutoPIPE KHK2-Addon 6.3x |
AutoPIPEKHK2.lic |
AutoPIPE PLUS 6.3x |
AutoPIPEPL.lic |
AutoPIPE Standard 6.3x |
AutoPIPE.lic |
AutoPLANT Drawing Flattener V3.0 |
drawingflattener.lic |
AutoPLANT Isometrics/Omni-Iso 1.5x |
Isometrics.lic |
AutoPLANT Isometrics/Omni-Iso 2.0x |
Isometrics.lic |
AutoPLANT Isometrics/Omni-Iso 3.0x |
Isometrics.lic |
AutoPLANT P&ID 8.1 |
PID.lic |
AutoPLANT P&ID/Omni-Flow 15.0x |
APPID.lic |
AutoPLANT P&ID/Omni-Flow 15.1x |
APPID.lic |
AutoPLANT P&ID/Omni-Flow 16.0x |
APPID.lic |
AutoPLANT P&ID/Omni-Flow 16.1x |
PID.lic |
AutoPLANT Piping V3.0x |
Piping.lic |
AutoPLANT Piping/Omni-Pipe 1.5x |
APPiping.lic |
AutoPLANT Piping/Omni-Pipe 2.0x |
APPiping.lic |
Bentley AutoPIPE 2004 Edition |
AutoPIPE.lic |
\program files\Bentley\program\licensing |
Bentley AutoPIPE Plus 2004 Edition |
AutoPIPEPL.lic |
Bentley AutoPLANT 2D Piping 2004 Edition |
2Dpiping.lic |
Bentley AutoPLANT AutoISOGEN PLUS |
AutoISOGENPL.lic |
AutoISOGENPL.lic |
Bentley AutoPLANT Drawing Flattener 2004 Edition |
Drawingflattener.lic |
Bentley AutoPLANT Equipment 2004 Edition |
Equipment.lic |
Yes |
Bentley AutoPLANT Isometrics 2004 Edition |
Isometrics.lic |
Yes |
Bentley AutoPLANT P&ID 2004 Edition |
PID.lic |
Yes |
Bentley AutoPLANT P&ID Conversion Toolkit 2004 Edition |
PIDConvert.lic |
Yes |
Bentley AutoPLANT Piping 2004 Edition
Piping.lic |
Yes |
Bentley AutoPLANT Raceways 2004 Edition |
3DElect.lic |
Yes |
Bentley AutoPLANT Structural Detailer 2004 Edition |
strucdetailer.lic |
Yes |
Bentley AutoPLANT Structural Engineering 2004 Edition |
strucengineer.lic |
Yes |
Bentley AutoPLANT Structural Modeler 2004 Edition |
strucmodeler.lic |
Yes |
Bentley Data Manager 2004 Edition |
Datamanager.lic |
Bentley Datasheets 2004 Edition |
Datasheets.lic |
Bentley Elementary Electrical Diagrams 2004 Edition |
eed.lic |
\\BENTLEY\PROGRAM\LICENSING\ |
Bentley Explorer 2004 Edition |
APExplorer.lic |
Bentley Explorer Interference Detection 2004 Edition |
Interference.lic |
Bentley Explorer NWD Export 2004 Edition |
NWDExport.lic |
Bentley Explorer Photorealism 2004 Edition |
Photorealism.lic |
Bentley Hookups 2004 Edition |
Hookups.lic |
Bentley Instrumentation and Wiring 2004 Edition |
Instrumentation.lic |
Bentley Interference Manager 2004 Edition |
ifmeng.lic |
Yes |
Bentley KHK2 for AutoPIPE Plus 2004 Edition |
AutoPIPEKHK2.lic |
Yes |
Knowledge.lic |
Yes |
navigator.lic |
Yes |
Bentley PlantFLOW 2004 Edition |
PlantFLOW.lic |
Bentley PlantFLOW Plus 2004 Edition |
PlantFlowPL.lic |
PlantFlowPL.lic |
Bentley PULS -100 node/1 compressor 2004 Edition |
Bentley PULS-1000 node/9 compressor 2004 Edition |
Bentley PULS-400 node/9 compressor 2004 Edition |
Bentley Signal Relay 2004 Edition |
eed.lic |
Yes |
Bentley SubStation Design Electric |
eed.lic |
Yes |
Bentley Vision 2004 Edition |
PLVision.lic |
Bentley WinNOZL API 650 2004 Edition |
WinNAPI.lic |
Yes |
Bentley WinNOZL KHK 2004 Edition |
WinKHK.lic |
Yes |
Bentley WinNOZL PD5500 2004 Edition |
WinPD55.lic |
Bentley WinNOZL WRC107 2004 Edition |
WinN107.lic |
Bentley WinNOZL WRC297 2004 Edition |
WinN297.lic |
Data Manager 15.0x |
Datamanager.lic |
Data Manager 15.1x |
Datamanager.lic |
Data Manager 16.0x |
Datamanager.lic |
Data Manager 8.1 |
Datamanager.lic |
Data Sheets 15.0x |
Datasheets.lic |
Data Sheets 15.1x |
Datasheets.lic |
Data Sheets 16.0x |
Datasheets.lic |
Data Sheets 8.1 |
Datasheets.lic |
Yes |
Drawing Flattener |
Equipment/Omni-Equip 1.5x |
APEquipment.lic |
Equipment/Omni-Equip 2.0x |
APEquipment.lic |
Equipment/Omni-Equip 3.0x |
Equipment.lic |
Explorer 6.1x |
APxplorer.lic |
Explorer 6.2x |
APExplorer.lic |
Explorer 7.0x |
APExplorer.lic |
Hookups 15.0x |
Hookups.lic |
Hookups 15.1x |
Hookups.lic |
Hookups 16.0x |
Hookups.lic |
Hookups 8.1 |
Hookups.lic |
Instrumentation & Wiring 16.0x |
Instrumentation & Wiring 8.1 |
Instrumentation 15.0x |
Instrumentation 15.1x |
Interference Detection 6.1x |
Interference.lic |
Interference Detection 6.2x |
Interference.lic |
Interference Detection 7.0x |
Interference.lic |
Knowledge Manager 16.1x |
Knowledge.lic |
Multi-Steel 2D 15.0x |
Multi2D.lic |
Multi-Steel 3D 15.0x |
Multi3D.lic |
Multi-Steel MODELER 15.0x |
MultiMOD.lic |
Navigator 15.1x |
PLVision.lic |
Navigator 16.0x |
PLVision.lic |
Not supported |
P&ID Conversion Tool Kit 15.0x |
PIDConvert.lic |
P&ID Conversion Tool Kit 15.1x |
PIDConvert.lic |
P&ID Conversion Tool Kit 16.0x |
PIDConvert.lic |
P&ID Conversion Toolkit 8.1 |
PIDConvert.lic |
PlantFLOW 6.1 |
PlantFLOW.lic |
Yes |
PlantFLOW PLUS 6.0x |
PlantFlowPL.lic |
PlantFLOW Plus 6.1 |
PlantFlowPL.lic |
Yes |
PlantFLOW Standard 6.0x |
PlantFLOW.lic |
PlantLIFE) Vision 8.1 |
PLVision.lic |
Project Server |
ProjServ.lic |
PULS-100 node/1 compressor 8.5
PULS1.lic |
Not supported |
PULS-1000 node/9 compressor 8.5
PULS3.lic |
Not supported |
PULS-400 node/9 compressor 8.0 |
PULS2.lic |
Not supported |
PULS-400 node/9 compressor 8.5
PULS2.lic |
Not supported |
STRAIT 5.0x |
STRAIT.lic |
Not supported |
Structural 3D 15.2x |
StrucEngineer.lic |
Structural 3D 16.0x |
StrucEngineer.lic |
Yes |
Structural 3D with NC 15.2x |
StrucDetailer.lic |
Structural 3D with NC 16.0x |
StrucDetailer.lic |
Structural Detailer 16.2 |
StrucDetailer.lic |
Yes |
Structural Engineering 16.2 |
StrucEngineer.lic |
Yes |
Structural Modeler 15.2x |
StrucModeler.lic |
Structural Modeler 16.0 |
StrucModeler.lic |
Yes |
Structural Modeler 16.2 |
StrucModeler.lic |
Yes |
Vision 16.1x |
PLVision.lic |
WinNozl API650 2.0x |
WinNAPI.lic |
WinNozl API650 3.0x |
WinNAPI.lic |
Yes |
WinNozl BS5500 2.0x |
WinPD55.lic |
WinNozl KHK 3.0x |
WinKHK.lic |
Yes |
WinNozl PD5500 3.0x |
WinPD55.lic |
WinNozl WRC107 2.0x |
WinN107.lic |
WinNozl WRC107 3.0x |
WinN107.lic |
Yes |
WinNozl WRC297 2.0x |
WinN297.lic |
WinNozl WRC297 3.0x |
WinN297.lic |
Yes |
Bentley Licensed Former IEZ ( Speedikon ) Products
Product |
License File Name |
Servable? |
ArCon-Plugin for Bentley speedikon |
speedikonArConPlugin.lic |
Bentley speedikon ProjectEditor |
speedikonProjectEditor.lic |
..\licensing\ |
Bentley speedikon 2D-WorkingDrawings |
speedikon2D.lic |
..\system\licensing\ |
Bentley speedikon Architectural |
speedikonArc.lic |
Bentley speedikon Industrial |
speedikonInd.lic |
Bentley speedikon ProjectExplorer |
speedikonProjectExplorer.lic |
..\licensing\ |
Bentley Licensed Former IEZ ( Speedikon ) Modules
Product |
License File Name |
Servable? |
Bentley Attribute filter for speedikon |
speedikonAttFilter.lic |
Bentley AVA Interface for speedikon |
speedikonAVAInterf.lic |
Bentley Quantity Takeoff for speedikon |
speedikonQTO.lic |
Bentley Solid Modeler for speedikon |
speedikonSmod.lic |
WindowDesigner (ArCon compatible) |
speedikonWindowDesigner.lic |
Misc.
Product |
License File Name |
Servable? |
ATMS Message Server |
atms-ms.lic |
\ATMS_ROOT\licensing |
Yes |
JT Exporter |
jtexporter.lic |
No |
JT Review |
jtreview.lic |
No |
Dual Licensing Info (Proposed)
Feature Name |
License File Name |
Default Path Location |
Servable? |
2D Piping |
2Dpiping.lic |
C:\program files\Bentley\program\licensing |
3D Electrical |
3DElect.lic |
AutoISOGEN PLUS |
AutoISOGENPL.lic |
AutoPLANT Isometrics |
Isometrics.lic |
Plant Piping |
Piping.lic |
Plant Equipment |
Equipment.lic |
Project Server |
ProjServ.lic |
* The license name for a nodelocked or server license that has been upgraded to the Inroads 8.4 version is bentleycivil.lic. For users that need to run both versions of Inroads (8.2 and 8.4) and they have not upgraded either the nodelocked or server license to 8.4 , the license file name must be selectcad.lic.
