Step 1: Identity the correct IPAddress for IMS 2.0 environment:
- Open Command Prompt – type CMD in the search window
- Ping IMS 2.0 – type ‘ping prod2-ims.bentley.com’ in the command prompt window
- The current IPaddress will be displayed in the response. Note this is not a static IPaddress and may change.
Step 2: Update hosts file with IPAddress
- Open NotePad, NotePad++ or another text editor (be sure to right click on the program and choose ‘Run as administrator’ or you will not be able to save changes)
- Click open and navigate to %WinDir%\System32\Drivers\Etc\
- Open the ‘hosts’ file (be sure that you have selected All Files (*.*)
- Add the following line to the hosts file: xxx.xx.xxx ims.bentley.com (where xx.xxx.xxx is the IPAddress from Step 1)
- Click File > Save
Note: Do not click Save As, this will result in creating a new file hosts.txt and will not update the hosts file.
NOTE: Do not forget to remove this entry from the hosts file when you have completed your testing.
