The Administrator has the ability to add or remove roles from individual users.
Use the following steps to accomplish this task.
1) Select 'Manage'
2) Select the user(s)
3) Select 'Modify Roles'
Once the Roles are displayed
4) Select the Roles you want to add or remove
5) Select 'Apply'
