Navigator Mobile uses the Bentley Single Sign-on to sign in to the app. Creating a Bentley Single Sign-on profile gives you access to a range of information, support, learning and project services. If you have a Bentley profile, you can use your email and password to log-in to the app.
If you do not have a Bentley Single Sign-on profile, you must register if you want to open your own models with Navigator Mobile.
