Access i-models from Personal Share
For quick access to your i-models when using MicroStation and Navigator, Windows or mobile version, you can easily publish your i-models to a personal space instead of browsing through Navigator to find your file.
To access i-models you have published to your personal share from MicroStation, select the Browse button from the File Open screen and then select Personal Share from the repositories list. Any i-models in your personal share are displayed here. Select the Refresh icon to refresh the Personal Share list.
Click the star icon to set the i-model as a favorite. When you set an i-model as a favorite, it downloads the file and makes it available for offline use. It also appears in the favorite list on the File Open screen.
For information on publishing files to your personal share from MicroStation, go to the Personal Share topic.
