Project Share lets you access i-models shared for your active project. Select Project Share from the File Open screen. All files synced to the project are displayed here.
Click the star icon to set the i-model as a favorite. When you set an i-model as a favorite, it downloads the file and makes it available for offline use. It also appears in the favorite list on the File Open screen.
If the Project Share button is not displayed for a project, you have not been granted permission to access Project Share.
For information on setting up Project Share, please refer to the ProjectWise sharing services page.
