View Orientation Tools
The View tools are a set of tools found on the Navigation Tools Menu in the upper right, which allows you to change the view of several standard view orientations. Select the tool to expand the tool group to see the available tools: Home View, Top View, Front View, Right View, Isometric View, and Toggle Camera. Toggle Camera changes the view from a perspective to orthogonal view.
