| | Applies To | | |
| | Product(s): | Bentley Navigator with AutoPLANT, ProjectWise & ProSteel | |
| | Version(s): | 08.09.05.70 | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
This is a complete install order for Bentley Navigator with AutoPLANT, ProjectWise and ProSteel products. Most of the listed software below is optional when installing PW Navigator. If the software package does not apply to you, just skip over it and install the next. Be sure to review the notes under each software or click on the ReadMe links for more information.
Install Order and Versions
- Support AutoCAD software
- MicroStation V8 XM Edition Software Prerequisite Pack - 08.09.04.01 (ReadMe)
- Required for Bentley View and Bentley Navigator
- Bentley View XM Edition - 08.09.04.51(ReadMe)
- Viewer for Document Manager and Vision
- Bentley ProjectWise V8 XM Edition - Client Setups - 08.09.04.89
- Only needed if running ProjectWise
- Bentley AutoPLANT P&ID XM Edition - 08.09.03.05(ReadMe)
- Bentley AutoPLANT Plant Design XM Edition - 08.09.03.30 (ReadMe)
- 3D piping package which includes Piping, Equipment, Raceways, Isometrics, & SpecGen
- Bentley Plant Framework XM Edition - 08.09.03.72 (ReadMe)
- Upgrade for 3d package, required for SP2 upgrade
- Bentley Process & Instrumentation XM Edition - 08.09.03.44 (ReadMe)
- Bentley AutoPLANT Plant Design XM Edition Service Pack 2- 08.09.03.49 (ReadMe)
- Upgrade for 3d piping package
- Bentley Plant Framework XM Edition - 08.09.04.47(ReadMe)
- Upgrade for framework for all Plant, required for ProjectWise
- ProSteel 3D R18.0 - 08.10.00.17(Documentation)
- Optional Structural software Package
- Bentley Navigator XM Edition - 08.09.05.70 (ReadMe)
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
