| | Applies To | | |
| | Product(s): | Bentley Navigator | |
| | Version(s): | XM Edition | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
There are several different ways to toggle on and off the representation of components. One way is to use Display Levels. This is a tech note on how to do this using Compoment Sets.
- Open Bentley Navigator (High Security).
- In the Microstation Manager dialog, change the user to "examples" and the projecct to "AutoPLANT".
- Open the drawing: C:\Documents and Settings\All Users\Application Data\Bentley\WorkSpace\Projects\Examples\AutoPLANT\dwg\main.dwg
- Go to the menu: Utilities > Component Sets...
Note: You will see with the already created component sets, you would have to create selection expressions in order to use this. - Right click on one of the rows and select "activate".
- Once it is activated, "uncheck" the column with a camera icon to hide it.
Product TechNotes and FAQs
Plant TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
