Navigator Mobile Publisher creates mobile i-models. A mobile i-model packages models and their related documents together to access 3D design model and its related information. Mobile i-models can be stored in any location to be used with the Navigator Mobile app. Note that i-models can be published with Bentley i-model Composer or MicroStation.
With this app, add and remove i-models and documents to publish a mobile i-model. When publishing, note that at least one file must be an i-model. For quick access, it allows saving and retrieving of settings. Publishing of mobile i-models can also be automated using available Macros.
Navigator Mobile Publisher doesn't currently support point clouds, rasters, or any DGN file that is not an i-model.
Download Navigator Mobile Publisher
[[wiki:Navigator Mobile Publisher - FAQ|Navigator Mobile Publisher - F.A.Q.]]
MicroStation V8i Supported Databases
