Navigator Mobile has three screens :
- The i-model Selection screen is where you view available i-models and select an i-model to open. You can also access the Settings menu on this screen. The Settings menu contains the Quick Start Guide, online resources, and sign-out option.
- The i-model Detail screen contains the search feature that allows you to search the available views and documents. You select the view to open of the 3D i-model or the document to open that is embedded in the i-model on this screen.
- The View screen contains the tools, tabs, and panels you can use to interact with the selected 3D view. Selecting an object within the view opens the Properties panel and the available tools to interact with the selected object. Objects may have links attached to them. You can see if an object has any links by opening the Document Links section of the Properties panel.
