List of the applications supported by Bentley i-model Composer
Product(s):Bentley i-model Composer
Version(s):08.11.09.293
Environment: N/A
Area: N/A
Subarea: N/A
The following is a list of some of the applications that the current edition of Bentley i-model Composer supports.
Application
Version
Format
Support Started In
Comments
ACIS SAT
SAT
Graphics
SELECTseries 1
Requires MicroStation to import to DGN first
Adobe PDF
PDF
Raster Reference
SELECTseries 1
Requires MicroStation to attach Raster Reference first
ADT / AutoCAD Architecture
DWG
Graphics
SELECTseries 1
AutoCAD MEP
DWG
Graphics
SELECTseries 1
Object Enabler required
Autodesk 3ds
3DS
Graphics
SELECTseries 1
Autodesk FBX
FBX
Graphics
SELECTseries 2
AutoPipe
9.4 SELECTseries 3 and above
JSM
Graphics, Properties
SELECTseries 3
Requires Bentley i-model Composer to import to DGN first
AutoPLANT P&ID
8.9, 8.11
DWG
SELECTseries 2
AutoPLANT PDW (3D)
2.01, 3.0, 8.6, 8.9, 8.11
DWG
SELECTseries 2
Bentley Architecture
8.9, 8.11
DGN
SELECTseries 2
Bentley Building Electrical Systems
8.11
DGN
SELECTseries 2
Bentley Building Mechanical Systems
8.9, 8.11
DGN
SELECTseries 2
Bentley Facilities Planner
8.11
DGN
SELECTseries 1
Facilities Planner generates V8i DGNs
Bentley GenerativeComponents
8.11
DGN
SELECTseries 1
Generative Components generates V8i DGNs
Bentley GEOPAK
8.9, 8.11
DGN
SELECTseries 1
GEOPAK generates V8i DGNs
Bentley InRoads
8.11
DGN
SELECTseries 1
InRoads generates V8i DGNs
Bentley Map
8.9, 8.11
DGN
Graphics
SELECTseries 1
Bentley MX
8.9,8.11
DGN
Graphics
SELECTseries 1
Bentley MXROAD
DWG, DGN
Graphics
SELECTseries 1
Bentley OpenPlant Modeler (3D)
8.11
DGN
SELECTseries 2
OpenPlant Modeler generates V8i DGNs
Bentley OpenPlant PowerPID
8.11
DGN
SELECTseries 1
OpenPlant PID generates V8i DGNs
Bentley Process & Instrumentation
8.9, 8.11
DWG
Graphics
SELECTseries 4
Bentley Rail Overhead Line
8.9, 8.11
DGN
SELECTseries 1
Bentley Rail Overhead Line generates V8i DGNs
Bentley Rail Track
8.11
DGN
Graphics
SELECTseries 1
Bentley Rebar
8.9, 8.11
DGN
Graphics
SELECTseries 1
Bentley Speedikon (AutoCAD)
8.11
DWG
Graphics
SELECTseries 1
Bentley Speedikon (MicroStation)
8.11
DWG
Graphics
SELECTseries 1
Bentley Structural Modeler
8.9, 8.11
DGN
SELECTseries 2
CAD-Duct
DWG
Graphics
SELECTseries 1
CAD-Mech
DWG
Graphics
SELECTseries 1
CGM
CGM
Graphics
SELECTseries 1
CIS/2
STP
SELECTseries 1
Requires Structural Modeler to import to DGN first
Common Raster Formats
C29, C30, C31, CAL, CALS, CT1, CIT, COT, CRL, TPE, LSR,
  DOQ, ECW, FLI, FLC, GIF, HMR, A, P, iTIFF, JPG, LRD, MPF, PCX, PNG, RGB, SID,
  TIF
Raster Reference
SELECTseries 1
Requires MicroStation to attach raster reference first
Google (KML & KMZ)
KML & KMZ
Graphics
SELECTseries 1
IFC
IFC
SELECTseries 1
IGES
IGS
Graphics
SELECTseries 1
ISM
8.11
DGN
SELECTseries 1
ISM generates V8i DGNs - comprises of ISM Revit plugin
  & Structural Synchronizer tool
JSM
JSM
SELECTseries 1
RequiresBentley i-model Composer to import to DGN first
MapInfo TAB
TAB
SELECTseries 4
MicroStation PowerDraft
8.9, 8.11
DGN
Graphics
SELECTseries 1
OBJ
OBJ
Graphics
SELECTseries 1
Parasolids
XMT
Graphics
SELECTseries 1
PDMS (via XMplant Import)
XML
SELECTseries 1
PDS (DRV)
DGN
SELECTseries 1
PlantSpace Design Series (3D)
8.9
DGN
SELECTseries 1
ProConcrete AutoCAD
8.11
DWG
Graphics
SELECTseries 4
ProStructures V8i (SELECTseries 2) includes ProSteel and
  ProConcrete. ProStructures is delivered for AutoCAD 2007-2010 32-bit.
ProSteel AutoCAD
R18.0, 8.9, 8.11
DWG
SELECTseries 2
ProSteel MicroStation
8.11
DGN
SELECTseries 2
Revit Architecture (former Revit Building)
RVT
SELECTseries 1
Supported via Revit plug-in which is available with
Revit MEP (former Revit Systems)
RVT
SELECTseries 1
Revit Structural
RVT
SELECTseries 1
Rhino (OpenNURBS)
3DM
Graphics
SELECTseries 1
RM Bridge
8.11
DGN
Graphics
SELECTseries 1
SketchUp
SKP
Graphics
SELECTseries 1
STEP AP203/AP214
STP
Graphics
SELECTseries 1
STL
STL
Graphics
SELECTseries 1
Text
TXT
Graphics
SELECTseries 1
XMpLant
XML
SELECTseries 1
