| Product(s): | Navigator Mobile Publisher | ||
| Version(s): | N/A | ||
| Area: | General | ||
Navigator Mobile Publisher is Bentley Systems application to convert i.dgn models to dgndb files or mobile imodel files that Navigator Mobile is able to view on an iPad. The first release is on January 18, 2013.
Navigator Mobile Publisher is the stand alone tool used to convert i.dgn files to .dgndb files or to .imodel files that Navigator Mobile is able to use for review. Navigator Mobile Publisher can also package other files into the dgndb file such as .pdf and .doc files.
Navigator Mobile Publisher can be downloaded by Bentley Select users from the Fulfillment Center: https://select.bentley.com/FulfillmentCenter/
No. Navigator Mobile Publisher does not integrate with i-model Composer it is a standalone program.
The .dgndb-issues file for your mobile i-model is stored in the same location as your mobile i-model. It contains issues Navigator Mobile Publisher encountered when publishing your i-model as a mobile i-model. You can send the .dgndb-issues file and the i-model file to Technical Support at selectservices.bentley.com.
“Unable to publish” displays if the added files are incompatible with Navigator Mobile Publisher.
If Navigator Mobile Publisher crashes, send the information to Microsoft. Bentley Systems, Inc. will receive this information as well and will investigate the reason for the crash.
Navigator Mobile Publisher does not support ProjectWise integration at this time.
Navigator Mobile Publisher cannot publish DGN files. It can only publish i-models.
Navigator Mobile Publisher cannot publish DWG files.
Navigator Mobile Publisher does not support rasters.
Navigator Mobile Publisher does not support Point Clouds.
Navigator Mobile Publisher is certified running on: Windows Vista, Windows Vista x64, Windows 7, Windows 7 x64, Windows 8, Windows 8 x64.
MicroStation V8i Supported Databases
