Applies To | |||
Product(s): | Navigator Mobile | ||
Version(s): | N/A | ||
Environment: | N/A | ||
Area: | General | ||
Subarea: | N/A | ||
Original Author: | Bentley Technical Support Group | ||
Navigator Mobile is Bentley Systems mobile application to be able to review 3D models on iPad. The first release is on January 18, 2013.
Navigator mobile is an app that can view models in a true 3D environment which allows panning, zooming, rotating, walking, and measuring.
Apple's iPad is the only supported tablet device for Navigator Mobile. The following iPads are supported.
iPad (1st generation) | Not supported |
iPad 2 (2nd generation) | Supported |
iPad (3rd generation) | Supported |
iPad (4th generation) | Supported |
iMini (1st generation) | N/A |
iOS 6.0 is the only supported iOS version.
Navigator Mobile can be downloaded from the Apple App store.
No, only the mobile i-models of the .dgndb file type can be used. Dgndb files are created with Navigator Mobile Publisher.
No. Navigator Mobile does not use the optimized i-model files. It only uses dgndb files created from Navigator Mobile Publisher.
Use the Navigator Mobile Publisher.
No redlining functionality is included in this release of Navigator Mobile.
No
No, that functionality was not enabled due to file size, and the fact that our models are not created on the iPad, they should be backed up elsewhere.
No, graphic information such as level, weight, and color is not captured in element properties. As well Tags are not captured.
No, this is not possible in the current version.
No, this is not possible in the current version but it is part of plans to add this in a future release.
MicroStation V8i Supported Databases
