| Product(s): | ProjectWise InterPlot Organizer and Professional, ProjectWise InterPlot Server, ProjectWise InterPlot Driver Pack, ProjectWise InterPlot Mid-Volume Driver Pack, ProjectWise InterPlot High Volume Driver Pack, ProjectWise InterPlot Raster Offline Driver Pack, ProjectWise InterPlot High Volume Driver Pack, ProjectWise InterPlot Raster Offline Driver Pack | ||
| Version(s): | InterPlot Organizer 08.11.xx.xx | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This technote lists the minimum techinal requirements for the ProjectWise InterPlot V8i Products.
ProjectWise InterPlot Organizer is required on each machine needing to submit plots to ProjectWise InterPlot Server. ProjectWise InterPlot Professional can submit plots to ProjectWise InterPlot Server or plot in a standalone mode without ProjectWise InterPlot Server.
Processor: Intel® or AMD® processor 3.0 Ghz or greater.
Memory: 512 MB minimum, 2 GB recommended. More memory will almost always improve performance.
Operating Requirements: Windows XP Professional 32-bit, 64-bit, Windows 7 32-bit, 64-bit, Windows Server 2003 SP1 or later 32-bit, or Windows Server 2008 R2 64-bit.
Supports 32-bit versions of the above Operating Systems running on 64-bit processors.
Supported File Formats: MicroStation (all versions), AutoCAD (releases 10 through 2010), raster files (such as TIFF, CALS G4, and JPEG), and ProjectWise InterPlot (DPR) files.
Memory: 1 GB of RAM minimum, 2GB recommended.
Operating System: Windows Server 2003 32-bit, Widnows Server 2008 64-bit, Windows Server 2008 R2 64-bit.
The following specifications are for using ProjectWise InterPlot's Digital Archiving Feature:
File server: To store the digital plots created for ProjectWise InterPlot Server archives, the file server must expose LAN Manager file shares that are accessible with Microsoft's Universal Naming Convention (UNC).
Web server: To view ProjectWise InterPlot Server archive web pages, Internet Information Services (IIS) 6.0 or later, Microsoft XML Core Services 4.0 SP3 or later.
Supported Databases: To store ProjectWise InterPlot Server archive attributes, Oracle9i*, Oracle10g (10.2g), Microsoft SQL Server 2005, Microsoft SQL Server 2008.
* Requires Oracle8 Client software
Supported Web browsers: Microsoft Internet Explorer version 6.0 or later.
ProjectWise TechNotes And FAQs
