| Product(s): | ProjectWise InterPlot Organizer, ProjectWise InterPlot Server, ProjectWise InterPlot Driver Pack, ProjectWise InterPlot Mid-Volume Driver Pack, ProjectWise InterPlot High Volume Driver Pack, ProjectWise InterPlot Raster Offline Driver Pack | ||
| Version(s): | V8 XM Edition | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This technote provides the minimum system requirements for the ProjectWise InterPlot XM version of products.
ProjectWise InterPlot Organizer is required on each machine needing to submit plots to ProjectWise InterPlot Server.
Processor: Intel® Pentium® or AMD AthlonTM
Memory: 256 MB minimum, 512 MB recommended. More memory will almost always improve performance.
Operating Requirements: Windows XP Professional, Windows 2000 Professional (SP3 or later), Windows 2000 Server, or Windows Server 2003 (SP1 or later)
Supports 32-bit versions of the above Operating Systems running on 64-bit processors.
Supported File Formats: MicroStation (all versions), AutoCAD (releases 10 through 2007), raster files (such as TIFF, CALS G4, and JPEG), and ProjectWise InterPlot (DPR) files.
Processor: Pentium® III 700 Mhz Processor minimum
Memory: 512 MB of RAM minimum, 1GB recommended. More memory will almost always improve performance.
Operating System: Windows 2000 Server (SP3 or later), or Windows Server 2003
The following specification are for using ProjectWise InterPlot's Digital Archiving Feature:
File server: To store the contents of ProjectWise InterPlot Server, the file server must expose LAN Manager file shares that are accessible with Microsoft's Universal Naming Convention (UNC).
Web server: Internet Information Services (IIS) 5.0 or later
Microsoft XML Core Services 4.0 (SP2 or later)
Supported Databases: Oracle9i*, Oracle10g*, Microsoft SQL Server 2000 and Microsoft SQL Server 2005
* Requires Oracle8 Client software
Supported Web browsers: Microsoft Internet Explorer version 6.0 or later
ProjectWise TechNotes And FAQs
