| | Applies To | | |
| | Product(s): | Digital InterPlot | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
The following driver packs can be configured to be compatible with the Windows Server 2003:
- InterPlot Driver Pack 03.01.00.24
- InterPlot Mid-Volume Driver Pack 01.02.01.15
- InterPlot High-Volume Driver Pack 01.03.00.25
- InterPlot Raster Offline Driver Pack 02.01.00.12
Before you install the driver pack, do the following:
- Edit the Group Policy to accept older (kernel) printer drivers:
- Key in the following from a command prompt: gpedit.msc.
- Select "Computer Configuration - Administrative Templates - Printers - Disallow installation of printers using kernel-mode drivers."
- Double click "Disallow installation of printers using kernel-mode drivers."
- Select "Disabled," and then click OK.
- Turn off the "File Pooling" feature.
- To turn off "File Pooling":
- Bring up the registry editor.
- Navigate to "HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Print"
- Select Edit > New > DWORD Value
- Enter DisableServerFilePooling for the name.
- When the value has been added, double click DisableServerFilePooling and change the value data to 1.
Product TechNotes and FAQs
ProjectWise TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
