Error 401 Using SSO to PW Web Client
Product(s):ProjectWise Web Server
Version(s):08.11.11.111
Environment: Windows Server 2008 R2
Area: Installation / Deployment
Subarea:
Original Author:Vickie Hewitt, Bentley Technical Support Group
Problem Description
When using Single Sign On Delegate User with Windows authentication in ProjectWise Web parts the web site opens correctly, but selecting Use Single Sign-On results in getting a machine login instead. Error 401 access denied is seen in the logs.
IIS is failing to use both methods of Authenitication (Negotiate and NTLM) when authenticating with Kerbos.
Kerbos is a computer network authentication protocol that is used as a ticket basis to allow communication over a network (non-secure)
 How IIS uses NTLM protocol and Kerbos protocol: http://support.microsoft.com/kb/215383
ASP.NET 2.0 Authentication Explained: http://msdn.microsoft.com/en-us/library/aa480475.aspx
Steps to Resolve
  1. Open IIS and select the website that is causing the 401 (login error)
  2. Open the "Authentication" property under the "IIS" header
  3. Right Click the "Windows Authentication" item and click "Providers"
  4. Move the NTLM to the top most spot.
If the Providers selection is not available under Windows Authentication it is possible to add the order manually in configuration file. Please locate the file:
C:\Windows\System32\inetsrv\config\applicationHost.config
Then find the Web Site that is causing issue and add the Providers order:
<location path="Default Web Site">
        <system.webServer>
            <security>
                <authentication>
                    <anonymousAuthentication enabled="true" />
                    <windowsAuthentication>
                        <providers>
                            <clear />
                            <add value="NTLM" />
                            <add value="Negotiate" />
                        </providers>
                    </windowsAuthentication>
                </authentication>
            </security>
        </system.webServer>
    </location>
