ASB TEST
 Product(s):ProjectWise Web Server
 Version(s):08.11.11.98
 Environment: N/A
 Area: Security
 Subarea:
 Original Author:Michael Dougherty, Bentley Technical Support Group
Error or Warning Message
XXXXXXX(Provide the exact message. Do not include user-specific paths--replace with "<path to file>" or similar.)XXXXXXX
Explanation
XXXXXXX(Provide a detailed explanation of the error message.)XXXXXXX
How to Avoid
Option 1 XXXX(Delete this heading if only one option exists.)XXXX
  1. XXXXXXX
  2. XXXXXXX(add more steps as needed)XXXXXXX
Option 2 XXXX(Delete this section if only one option exists.)XXXX
  1. XXXXXXX
XXXXXXX(Add links as needed for other relevant Be Communities content.)XXXXXXX
