| Product(s): | ProjectWise StartPoint | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
ProjectWise StartPoint has been tested against the following SharePoint versions:
| Application | Version |
| Windows Sharepoint Services 2.0 | SP2 or higher |
| Windows Sharepoint Portal 2003 | SP2 or higher |
ProjectWise StartPoint for AutoCAD has been tested against the following AutoCAD versions:
| AutoCAD | 2002 |
| AutoCAD | 2004 |
| AutoCAD | 2005 |
| AutoCAD | 2006 |
ProjectWise StartPoint is built into the following MicroStation versions:
| MicroStation V8 XM Edition | 08.09.02.77 and higher |
| MicroStation PowerDraft V8 XM Edition | 08.09.02.77 and higher |
| Bentley View V8 XM Edition | 08.09.02.77 and higher |
ProjectWise TechNotes And FAQs
