| Product(s): | ProjectWise StartPoint 2007 | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Note: The SharePoint versions listed below are 32-bit applications. 64-bit SharePoint servers are also supported via the 64-bit StartPoint Service.
ProjectWise StartPoint has been tested against the following SharePoint versions:
Application |
Windows SharePoint Services 3.0 |
Windows SharePoint Portal 2007 |
ProjectWise StartPoint for AutoCAD has been tested against the following AutoCAD versions:
Application |
Version |
AutoCAD |
2002,2004, 2005, 2006, 2007, 2008 |
Autodesk Architectural Desktop |
2004, 2005, 2006, 2007 |
Autodesk Landscape Desktop |
Autodesk Mechanical Desktop |
ProjectWise StartPoint is built into the following MicroStation versions:
Application |
Version |
MicroStation V8 XM Edition |
08.09.04.51 and higher |
MicroStation PowerDraft V8 XM Edition |
Bentley View V8 XM Edition |
Bentley Redline XM Edition |
Bentley Navigator V8 XM Edition |
08.09.04.57 |
ProjectWise TechNotes And FAQs
