Authentication Failed. Delegate user is not setup correctly. (Solution 500000105439)
 Product(s):ProjectWise Web Server
 Version(s):N\A
 Environment: N\A
 Area: Configurations
 Subarea: N\A
 Original Author:Steve Boniwell, Bentley Technical Support Group
When trying to log into the ProjectWise Web Server, users were getting
the following error message "Authentication Failed. Delegate user is not
setup correctly. Additional Details: Failed to connect to the remote
server application.."
WebServer was resolving to incorrect IP address so changes were made to
the dmskrnl.cfg file;
[Listener]
Port=5800
BindAddress=Server IP Address
[TeamMate]
ServerName=FQDN Server Name
ServerIPAddress=IP Address
