[[5543|A]] [[5544|B]] [[5545|C]] [[5546|D]] [[5547|E]] [[5548|F]] [[5549|G]] [[5550|H]] [[5551|I]] [[5552|J]] [[5553|K]] [[5554|L]] [[5555|M]] [[5556|N]] [[5557|O]] P [[5559|Q]] [[5560|R]] [[5561|S]] [[5562|T]] [[5563|U]] [[5564|V]] [[5565|W]] [[5566|X]] [[5567|Y]] [[5568|Z]]
Pane
A section of the application window, usually separated by a border.
Parent document
See master document.
Password
In combination with a user name, a password is used to authenticate the user when attempting to log in to adatasource.
Permissions
The items that set what a user can and cannot do, when access control is used.
Placeholder document
A ProjectWise document that does not have an electronic file attached to it.
Port 5799
The default port, as specified in the dmskrnl.cfg file, through which ProjectWise Integration Servers and ProjectWise Gateway Services receive broadcast requests from ProjectWise Explorer and ProjectWise Web Server clients. Also referred to as the broadcast port. (See broadcast port glossary entry for longer definition)
Port 5800
The default port, as specified in the dmskrnl.cfg file, through which ProjectWise Integration Servers and ProjectWise Gateway Services listen for incoming TCP connections. Also referred to as the listener port. (See listener portglossary entry for longer definition.)
Preview pane
In ProjectWise Explorer, below the document list, displays properties of the selected folder
or document.
Print set file
A .PSET file created in Print Organizer (in MicroStation V8i or later) that is used to print a number of documents at the same time (in batch) from either ProjectWise Explorer or integrated MicroStation.
Priority search
This type of search for references will only search selected folders, and they will be searched
in the order they are listed in the Scan for References wizard.
Privileges
General term for the settings that determine what you are allowed to do with documents and folders and projects. Program associations The programs linked to and defined for use with the specified ProjectWise applications.
Project
Projects are a kind of super-folder that provide a single place to manage and organize documents, data and resources related to a given real-world project. Projects can contain or reference saved searches, documents, folders, subprojects, components, links to other sources of data, and so on.
Project-aware saved search
A search that is defined to search for documents, where the starting point of the search is the project in which the search itself is saved. When you copy a project-aware saved search to another project, the search path of the new saved search is updated to reflect the project it was copied to.
Project type
Project types are similar to environments, except that project types can only be assigned to projects. Project types are created in ProjectWise Administrator, and contain custom project properties. Once a project type is created in ProjectWise Administrator and assigned to a project in ProjectWise Explorer, users can open the Project Properties dialog and enter values for those custom project properties on the Properties tab.
The ProjectWise module that lets you create and manage datasources.
ProjectWise Automation Service
The portion of ProjectWise that lets you extract components from ProjectWise documents, and then manage those components within ProjectWise.
ProjectWise Caching Server
The ProjectWise server module to install when you want to set up a storage area on a computer other than the Integration Server computer. The ProjectWise Caching Server cannot be installed on computers on which ProjectWise Integration Server or ProjectWise Gateway Service is already installed.
ProjectWise Distribution Service
The portion of ProjectWise that lets you identify a group of documents, have them rendered using ProjectWise InterPlot Server, and then send the rendered documents to another folder, another datasource, or if you have the proper connectors, to another document management system. You can choose to send copies of the original documents along with the rendered copies to the target location, or you can choose to skip the rendering and simply use ProjectWise Distribution Service as a way to copy documents from one place to another.
The main client interface for ProjectWise, from which users can check out, open, modify, and otherwise manage their ProjectWise documents.
The ProjectWise server module to install for datasource list publishing. The ProjectWise Gateway Service cannot be installed on computers on which ProjectWise Integration Server or ProjectWise Caching Server is already installed.
ProjectWise iDesktop Integration
An option of the ProjectWise Explorer installer that integrates supported desktop applications (such as MicroStation, Bentley Navigator, AutoCAD, Microsoft Office) with ProjectWise Explorer. When integrated, users can check out, open, and check in ProjectWise documents directly from the integrated application.
ProjectWise Indexing Service
When the Full Text Indexing feature of ProjectWise Integration Server is installed, ProjectWise Integration Server contains its own Indexing Service which maintains the full text index catalog, accepts text extraction updates to the catalog, and executes full text searches as configured and run from ProjectWise Explorer and Web Parts. You can use the ProjectWise Integration Server's Indexing Service, or you can install a devoted ProjectWise Indexing Service on another computer to off-load work from the main Integration Server. ProjectWise Indexing Service cannot be installed on a computer on which ProjectWise Integration Server is already installed.
The primary server of ProjectWise, and is the server on which your datasources are created. Every other ProjectWise module, whether it is a user client, an administrative client, or another server, is said to be a client of the ProjectWise Integration Server.
ProjectWise Messenger
The mechanism optionally available on each ProjectWise Explorer computer for sending and receiving messages between other ProjectWise users, and for receiving messages generated by messaging agents in ProjectWise Administrator.
ProjectWise Orchestration Framework Service
ProjectWise Orchestration Framework Service is a required supporting feature of ProjectWise Distribution Service, ProjectWise Automation Service, and the automated document processors that can be installed with ProjectWise Integration Server.
ProjectWise User Synchronization Service
The ProjectWise module that leverages Windows domain or Active Directory accounts in order to create ProjectWise user accounts. Once these ProjectWise user accounts are created, you can use ProjectWise User Synchronization Service to keep those accounts synchronized with any changes made to their domain or Active Directory counterpart.
ProjectWise Web Parts
ProjectWise Web Server Components for Web Parts is used to provide a web browser interface for ProjectWise users. Web browser-based access to ProjectWise is intended for casual users who are in remote, possibly low-bandwidth locations. ProjectWise Web Parts can be set up in a Microsoft SharePoint portal, or they can be configured on a computer without SharePoint. Once you install and deploy ProjectWise Web Parts, there are five web parts that you can add to your portal or web page.
Properties
The general term for all of the general and custom attributes which can define a document, folder, or project.
Proximity search
This type of search for references will start the search with the top folder selected, then will work its way down until all subfolders are searched.
Publish
When you select a document for viewing from Web Parts, that document is converted to a format that is able to be displayed by your browser, and is said to be published. DGN and DWG documents are published using ProjectWise Publishing Server.
Purge
To remove local copies of documents from the working directory.
