| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.09.04.xx | ||
| Area: | Web Services | ||
Design Compare utility displaying inconsistent results
Update the web garden value (in IIS) from 2 to 1. Default is 1 for IIS configuration.
In IIS Manager, expand the local computer, expand Application Pools, right-click the application pool, and then click Properties. Click the Performance tab, and below you will see the Web garden settings. Ensure this is set to “1”.
